Results 1 to 1 of 1
04-21-2009, 06:20 PM #1
- Aug 1999
- No Where
Corvette Ignition Coils - No Fire In The Hole
The bottom line for C1/C2/early C3 ignition coil troubleshootingThe ignition coil in C1, C2, and early C3 Corvettes is truly an amazing little device. An ignition coil is a type of pulse transformer that multiplies the low voltage received from the battery or alternator to many thousands of volts when the breaker points open and close. The coil contains a primary winding, a slot iron core, and a secondary winding. The high-voltage output of the coil is directed to the appropriate spark plug by the distributor. Hence, without this high voltage, there is no spark and, consequently, internal combustion can't take place within the engine.
Photo Gallery: Corvette Ignition Coils - C1-C3 Coil Troubleshooting Guide - Corvette Fever Magazine
More...
Ignition Coils
By oharam in forum General HelpReplies: 8Last Post: 03-16-2011, 06:22 AM -
Ignition Coils Needed
By tommyjt2006 in forum Parts Wanted / TradeReplies: 1Last Post: 10-16-2007, 10:51 AM -
Fire in the Hole compilation
By SiggyZ in forum Multimedia SectionReplies: 6Last Post: 08-21-2007, 10:52 AM -
Fire in the hole!!
By BadBlueBird* in forum Almost Anything GoesReplies: 11Last Post: 06-03-2007, 08:20 AM -
rust on Ignition Coils?
By arenberg13 in forum General HelpReplies: 0Last Post: 12-10-2005, 09:03 PM
