Thread: dead t/a
    ny
    arctic white
    2002 ws6 trans am
    dead t/a
    just wanted to know if anyone else was having this problem i have a 2002 ws6 i just did the whole stereo over including a new viper alarm and optimum yellow top however if i let the car sit for more than 2 weeks the car is dead winter just kills it even faster i duno what to do i had the battery swapped out for a new one so i dont think that is it if anyone could shed some light on the situation id greatly appreciate it
    Wisconsin Rapids, WI
    1999 Z/28 M6
    optimas don't like to sit for more than a week or so without having the car started and optimas don't take too well to winter.
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Parasitic draw somewhere.. get a battery tender if you keep all the electronics
    You can do a simple draw check:
    With the ignition key "off", disconnect the positive cable from your battery and either hook up a test light or cobble up an automotive light bulb (12 volt) with two wires. One lead goes to your positive battery cable and the other to the postive battery "post". The brighter the light, the greater the draw on your electrical system. Obviously, certain systems draw power even with the car off, however, it should be relatively small, ie. the light should be dimly lit.
    With the test light installed, you can then disconnect fuses to determine the main source of your draw. Pull them one at a time and see if the intensity of the light decreases. Obviously, start with the stereo and alarm equipment to see if there is a problem there. For example, if the switched lead to your amp has power all the time, your amp could be drawing power even with the system off.
    If your draw is too great, it will burn out the light bulb -- a test light should be fine though. If everything seems to check out, then look at your battery and charging system as the possible culprits.
    ny
    arctic white
    2002 ws6 trans am
    thanks alot guys this has been driving me crazy for months now ill try those tests and see what the outcome is thanks again
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    Some people have had either the ashtray light or the glovebox light stay on. Wouldn't hurt to check those too.
    Beaver Dam KY
    79 T/A -91 Firebird
    Quote Originally Posted by bigrondownhiller View Post
    Where is the ashtray light???
  1. He's dead, now what?
    By SHines-IT in forum Almost Anything Goes
    Last Post: 07-17-2010, 11:57 PM
  2. RMS is dead.....GO AVS !!!!!!
    By 98T/Aformula. in forum Rocky Mountain Members
    Last Post: 07-08-2008, 06:42 AM
  3. Dead MAF?
    By JwMonE99 in forum General Help
    Last Post: 12-27-2007, 01:40 AM
  4. E40 is NOT Dead!!!
    By LS2Tuner in forum Almost Anything Goes
    Last Post: 02-21-2007, 06:05 PM
  5. the T/A is Dead
    By NeXuS in forum Firebird / WS6
    Last Post: 11-28-2005, 06:55 AM
