Results 1 to 20 of 85
Thread: MAF, screen removal ?
04-18-2009, 11:15 AM #1Junior Member
- West Palm Beach, FL
Black- 1999 WS6 Conv.
anybody remove the screen from the stock MAF. Is it a problem to do so
(it seems restrictive). ??
04-18-2009, 11:19 AM #2Junior Member
sorry, searched and found the answer. Leave it in !!!
04-18-2009, 12:23 PM #3
04-18-2009, 02:45 PM #4Sold: LS1 '85 El Camino
- Dec 2005
- Laurel, Maryland
Do it.
04-18-2009, 03:59 PM #5
I took mine out. No problems at all
I did it on all 3 f-bodies I had.
04-18-2009, 04:39 PM #6
De-screening the MAF is so hit or miss. IMO, the Cons far out weigh the Pro's. Look at it as how much HP you MAY gain from doing it. Then look at how much headache it may cause for a amount of HP that is so questionable. I have heard people (on here) say they actually 'felt' a HP increase from de-screening the MAF. I find it 100% impossible to actually 'feel' any HP increase from doing this. Leave your MAF alone. Look into other proven areas to gain HP.
04-18-2009, 07:25 PM #7
I 100% agree with Hi-Po. Lets just say that you gained 5hp which is a far stretch. Then lets say a piece of debri (spell?) hits the MAF wires and wrecks it. Now your out around $300 for a damn sensor for a questionable gain. I ported mine but left the screen in for insurance. In my 76,000 miles I have seen one thing the screen stopped from entering the engine. Thats one thing I didn't have to worry about
┌∩┐(◕_◕)┌∩┐
wouldn't want to fight them!
04-18-2009, 11:30 PM #8Impounded
- Oct 2007
- Beaver Dam KY
Its hit or miss...
There is no right answer actually..
I swore by leaving it in and got pissed and popped it out.. Runs fine to me....
04-19-2009, 06:25 AM #9Junior Member
Thanks everyone, I am leaving it in for now.
BlackSS ... I ported & polished my TB, but how do you port the MAF ?
04-19-2009, 12:44 PM #10
04-19-2009, 12:55 PM #11
Thats totally not true. The MAF ends, you cut the metal out of them. Its actually quite simple. I don't really know if it helps that much, but it keeps you busy and may make a difference.
http://www.installuniversity.com/ins...afapalooza.htm
04-19-2009, 01:02 PM #12Impounded
- Oct 2007
- Beaver Dam KY
04-19-2009, 01:43 PM #13
anything you "think" you feel from descreening the MAF is in your head. leave it in
04-20-2009, 09:01 AM #14
I would just leave it in. They put it in there for a reason. And it can help, even though you wont know it till you look at it. When i bought my car i went to clean the air filter and noticed there was something in the ducting. I took it off and my MAF was packed with birdseed the a mouse must have put in there somehow. If i hadnt had the screen that wouldve been sucked down into my engine.
04-20-2009, 10:49 AM #15Junior Member
I am convinced, it stays in.
I am just wondering if there is a way to free up some more air flow. Has anyone had luck with the smooth bellows or possibly a larger diameter after market MAF.________________________________________
99 WS6, Black Vert M6
Lid, K&N, PPTB, PRC 2.5 heads, Comp Cam 228/.588 112 lsa w/ suporting mods, 96mmNW TB,102mmFast, Pacesetter LT's, ORY, Magnaflow, Tune, 4:10's, Aurburn Posi, LS7 Clutch, B&M shifter, Stano/ Koni , 18" C6 rims, 295/30 Kumho tires.
04-20-2009, 11:05 AM #16Sold: LS1 '85 El Camino
- Dec 2005
- Laurel, Maryland
No offense and I'm sorry, but this is one the dumbest comments I see on car forums. The EGR and AIR systems are put on our cars FOR A REASON, but 90% (the other 10% being CA residents or people wanting to keep everything stock and unmolested) of members on here remove them for various reasons.
The reason I took mine off is because I have the intake air filter there. That is supposed to stop anything from getting inside the engine. If the MAF was before the filter, then I could see leaving it on, but its not, so yeah...
Disclaimer: I'm not stating I gain any hp off of it...just weight reduction off of the front
04-20-2009, 01:21 PM #17Impounded
- Oct 2007
- Beaver Dam KY
I gotta agree. The corvette mafs dont have the screen. If you have something missing the filter or have a mouse packing stuff in there then you have OTHER issues..
Stock maf =great!
Descreened maf= ok to me. i did it.
Ported maf = tune it or go SD
04-20-2009, 01:45 PM #18
Nah it totally is true. Porting the MAF RUINS it, so do the ported MAF ends. They make them inconsistent, non-repeatable in measurement and jack your fueling WAY out until you retune for them. A 40% change in fueling is insane, and that's what you can expect. Don't take my word for it though, look at this guy: http://www.ls1tech.com/forums/pcm-di...ar-dies-2.html Unhooks his 'ported' MAF and his trims go from +35 to +45% down to 4% in SD with the MAF unhooked. I junk about 1-2 MAFs a month for customers who have 'ported' them and now they won't run the same AFR twice in a row on the dyno to save their lives.
There is just not some big gain to be had by jacking the MAF around. I don't understand the high volume of threads that concern this. The MAF is a [once] calibrated sensor that is directly responsible for fuel delivery to the car. How can you 'port' a MAF and have any idea of it's impact without the software to log before and after and fix the AFR change that you cause when you mod them?
04-20-2009, 01:50 PM #19
I'm with these guys (Sorry Preston,lol) I ported and descreened mine, and have not had one problem, and as camino said, you should not be getting shit into your MAF, thats a filter problem.... If you look at a stock MAF, screen blade and all, then a ported descreened one.... there is night and day difference, yea it may be only worth a few ponies, but to me its giving the engine every chance of flowing better... Some will also argue that it causes tuning problems, but i've seen that go both ways....
04-20-2009, 01:55 PM #20
Thank you! Too many people are still swinging from the "Port your maf, Do ANYTHING to your MAF" tree. What is so hard about leaving the MAF alone? I dont think I will ever understand it. Im just going to start coping and pasting that response in every thread I see about MAF porting/screening.
Wanted: MAF screen
By 02silverbird in forum Parts Wanted / TradeReplies: 3Last Post: 10-27-2010, 11:12 AM -
maf screen removal
By tholly in forum General HelpReplies: 31Last Post: 06-12-2009, 04:38 PM -
De-screen MAF? Yes or No...
By StuntmanMike in forum General HelpReplies: 122Last Post: 11-24-2007, 11:58 AM -
Need new MAF screen, Help!!!
By FLEX3269 in forum External EngineReplies: 2Last Post: 11-13-2007, 08:15 PM -
WTB: Screen for ls1 maf or cheap maf with screen
By carman in forum Parts Wanted / TradeReplies: 2Last Post: 10-12-2005, 10:12 AM
