Results 1 to 14 of 14
Thread: 408 Stroker windage tray
04-16-2009, 08:03 PM #1
- Feb 2006
- U. S And A Greatest country in all of world
Stock- 2002 Camaro
So the problem i have is that the rod bolts are hitting the windage tray on the new motor. so can i just put some washers between the windage tray and the block, or is there some other way? Thanks in advance for the input.
here are some pics of the new toy!!!!
04-16-2009, 10:22 PM #2
lookin good, that's about as much I can help
04-16-2009, 10:48 PM #3
04-16-2009, 11:28 PM #4
04-17-2009, 01:41 AM #5
- Mar 2008
- OHIO"S only 9 second GTO
Phantom Black Metalic- 2005 GTO
04-17-2009, 07:20 AM #6
04-17-2009, 07:25 AM #7
04-17-2009, 07:26 AM #8
04-17-2009, 09:16 AM #9
- May 2006
- Canada
Blue 1997 Trans Am(Sold)- Pewter 2001 Trans Am Vert
damn looks like I was slow on the draw, but I'll just confirm it. Yes you need spacers. The washers you chose are perfect. Good luck with the rest of the install.
04-17-2009, 09:25 AM #10
- Mar 2007
- Henryetta/Tulsa Oklahoma
What they all said, + some more MORAL support
04-17-2009, 09:50 AM #11
04-17-2009, 09:51 AM #12
04-17-2009, 05:43 PM #13
i ended up notching the windage tray (cut holes) where the rods hit.
04-18-2009, 03:00 AM #14
- Mar 2008
Wanted: LS1 Oil Pan, Windage Tray, and Pick-up Tube
By My00Z28 in forum Parts Wanted / TradeReplies: 2Last Post: 05-24-2012, 06:33 AM -
windage tray
By leon phelps in forum Internal EngineReplies: 8Last Post: 04-26-2010, 01:44 PM -
Wtb LS1 F-Body Oilpan, Pickup and windage tray
By 95fbformula in forum Parts Wanted / TradeReplies: 2Last Post: 07-01-2009, 02:36 PM -
oil pan clearance to windage tray
By lc308 in forum General HelpReplies: 0Last Post: 01-15-2009, 01:58 AM -
WTT: LS2 GTO oil pan setup for LS1 Fbody (pickup, windage tray etc...)
By burtoncr in forum Parts Wanted / TradeReplies: 0Last Post: 07-17-2007, 06:36 AM
