Results 1 to 10 of 10
    Senior Member GottaHaveLS1's Avatar
    Connecticut
    1999 Trans Am M6
    lowering process
    How difficult is it to lower an F body? Are lowering springs the only thing you need? I heard that if lowering springs are used on stock struts, it will gradually damage the struts. Can someone describe what i would have to do once i have the new springs?
    Junior Member krazyz28's Avatar
    Bay Area, California
    1999 Camaro Z28
    Quote Originally Posted by GottaHaveLS1
    You will get about 5,000 miles or so from the stock struts/shocks after installing springs with a 1 1/2inch drop. Also I would get sub frame connectors as soon as u can if you havn't already done so. I would recommend purchasing the springs/struts together that way you don't have to do things twice.
    After installing the springs/struts make sure you get an alignment as soon as possible to prevent improper tire wear.
    Also will you be lowering the car yourself?
    Connecticut
    1999 Trans Am M6
    I would probably do the lowering myself. The guides on ls1howto.com are very clear and helpful.
    don't use subframes unless your tracking b/c they aren't worth the weight. get front sway bars instead. If your gonna do springs, yes do shocks. SLP has a kit for 600, or you can spend up to 2000 on koni's shocks and BMR springs. It's all up to you.
    Buffalo, NY
    1999 Trans Am WS6
    I would do subframe connectors so you can strengthen the chassis. You can get Koni Single Adjustable shocks for $800 + $25 shipping from www.stranoparts.com. They also make Double adjustable's $1,300 but most people recommend the SAs because there's a lot more room for error with the DAs. Lowering springs usually run from $200-$250.
    Pro 5.0 shifter, CAGS, Borla Exhaust, Direct-Flo Lid, K&N Air Filter, Fast Toys Ram Air Kit, BMR STB, BMR Adjustable PHB, BMR Boxed & Welded SFCs, Metco Boxed LCAs w/ Relocation brackets, Metco Driveshaft safety loop, Koni SA Shocks, Eibach Pro-Kit.
    the whole world is crazy but me. SFC's are a waste
    Buffalo, NY
    1999 Trans Am WS6
    Quote Originally Posted by dipherentdesign
    Why would it be a waste to stiffen the chassis, especially on a car that is a convertable or T-Tops? If you put down enough power your going to twist the car's frame. SFC's will prevent that from happening. Ok, maybe a stock F-body won't need SFC's but when you start putting down serious RWHP then SFC's are a must. IMO any F-body that is a convertable or T-Tops, SFC's are a must even if it's stock. So you have a trade off happening, you gain weight which is bad, but your car gains strength which is good. A reduction in chassis flex is going to help you any way you look at it.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    lowered a 98 once. the rear shocks immediately bottomed out when hitting a bump. i think they were jamex springs. so, shorter shocks are in order.
    Boosted Foolz
    Buffalo
    BlAcK
    1998 FiReBiRd FoRmUlA
    i put eibach sportlines on my 98 formula with teh stock rear shocks, it has 83,000+ miles on em and there still fine, that was a year ago, i replaced the fronts
    1999 Camaro Z28
    I agree with bad99ta. Subframe connectors are a must on any fbody that is a convertible or t-top especially if you run tires that can hook up. BMR boxed subframe connectors only weigh in around around 20-30 pounds. Most stereo systems weigh more than that.
    I waited way too long to install mine and am paying for it now. Car has 45,000 miles on with visible signs of a twisting chassis. Most of my body paneling doesn't line up anymore and the driver side t-top has a slightly visible air gap in it now when looking from behind the car. Plus My torque arm is now warped which will be replaced shortly.
    If you drive your car even somewhat hard, then subframe connectors are a must to help keep your suspension geometry where it should.
  1. Who Needs Due Process
    By GTP231 in forum Political / Debate Forum
    Last Post: 06-16-2016, 05:56 PM
  2. Process
    By Sarge in forum Appearance Section
    Last Post: 12-28-2010, 07:38 AM
  3. tuning process
    By dafizzman1 in forum Computer & Tuning
    Last Post: 08-06-2007, 04:09 PM
  4. In the process of an LS1 conversion S-10
    By lowonair6173 in forum Member's Rides
    Last Post: 03-26-2006, 07:11 AM
