Results 1 to 3 of 3
    Member JattGunMan's Avatar
    cali
    2000 ss
    Clutch Return Spring Bushing??
    Does any know the part number for the clutch pedal return spring bushings????
    Junior Member 99TALS1DRVR's Avatar
    Mar 2009
    Indianapolis,IN
    Blue
    99 Trana Am
    I have a question. what problem is this part going to fix? and where is this part located on your car. I only ask because my clutch pedal at times doesnt want to return all the way to the up position. and I dont think it is a hydraulic issue
    Just a farmboy V8MUSCLE's Avatar
    Montpelier, VA
    2000 Pontiac Trans Am
    mine wont come up after i am hard on it. after about 5 or so minutes it will come up. if you just "pump" the free play in it i have found it will come up.
  1. Help: Clutch pedal return spring
    By 02fhc009 in forum Manual Transmission
    Last Post: 08-25-2010, 03:48 PM
  2. clutch pedal return spring
    By Ramairgod84 in forum Manual Transmission
    Last Post: 11-15-2009, 03:06 PM
  3. Clutch Pedal Return Spring - Help
    By RandomOmen in forum Manual Transmission
    Last Post: 05-07-2008, 09:18 AM
  4. 2001 Camaro clutch return spring PLASTIC BUSHING
    By Reddogmr57 in forum Manual Transmission
    Last Post: 03-18-2008, 06:25 PM
