Results 1 to 19 of 19
Thread: Can i make them pay?
04-14-2009, 02:06 PM #1James Bond
- Aug 2007
- Texas
Ok so about 2 months ago i get a check engine light for "insufficient coolant temp for closed loop fuel control." Which means i have a stuck thermostat.
Well the whole time i've owned my car its run about 175-180 degrees, so i assumed it had a 180 thermo in it. seeing as how the previous owner was dead, I couldnt really ask him what had or hadnt been done to the car.
So I go to ABC auto and pick up a 180 thermo. he said its the right part, but since its a 180, not 195, its not OEM. it was a Parts Master part.
I get home, do the install, and the new one is offset, the thermo isnt exactly in the middle of the housing. the old ones in the center, but the new ones not. btw, it turns out my old one was a factory 195, it just ran cold for some reason. but the new one fits just right, and everything about it looks exactly the same, its just off center, but like i said, aftermarket part. not just real concerned that it looks different.
A week later i start leaking coolant, cant figure out where or why. And after a month of going to shop, and flushing and refilling my system, turns out my intake gaskets busted, right where the thermostat is....cost me $550 to repair.
I went back and got another thermo, this time a factory one....the guy at the desk admitted the other might be the wrong part.
So if their wrong part cost me over $600 in damage, could they be liable?
heres some pics. left is my old one, right is the new one...second pic is the boxes with part numbers.
04-14-2009, 02:21 PM #2おれわCamaroがいじん!
- Apr 2007
- Washington D.C.
Black- 1998 Chevrolet Camaro SS
Definitely yes....If they ordered the wrong part for you that is their mistake, and you should go talk to them about this ordeal. They need to cough up some money to pay towards your car.
04-14-2009, 02:26 PM #3
I would'nt hold my breath on it. If it did'nt look right you should'nt have installed it. Sorry but I think you're S>O>L.
Always check the part at the counter.....
04-14-2009, 02:45 PM #4
04-14-2009, 03:35 PM #5
Regardless you are SOL.... and by no means am I taking their side, but just telling you what they will say. YOU chose to put an aftermarket part on that wasn't close to being OEM. And also, the intake is leaking, not the thermostat...ie not their problem. And doesn't that thermo plug into the water pump? Either way, I doubt they will take any responsibility for that problem. Best of luck though! It may be worth talking to them.
2018 Tahoe - Silver - OEM
04-14-2009, 03:48 PM #6
I think it depends how good you are at negotiating.
04-14-2009, 03:49 PM #7
04-14-2009, 04:01 PM #8I have a need for speed!
- Dec 2006
- Standish,Maine
Artic White- 00 SS Vert.
Sorry, but that thermostat isn't what caused your intake to start leaking. When you replaced the thermostat, your engine coolant temp. went up higher than it did before and blew out your gasket. 3.8Ls are known for leaking intake gaskets.
JIGGER RACIN'
2000 Camaro SS, vert., auto., LS6 intake manifold, SLP lid, K&N filter, SLP LoudMouth II, C5 Z06 replica 17x9.5 rims
1/4 mile time = 13.310 sec. @ 105.22 mph, 2.051 60'
http://www.cardomain.com/ride/2939958
http://i158.photobucket.com/albums/t...amarolaeft.jpg
04-14-2009, 04:09 PM #9
04-14-2009, 04:30 PM #10
In that case you should have drained some of the coolant and it wouldn't be their fault. This is good though. Keep arguing. If you can beat down the LS1 forums you're equipped to go in there and debate this.
04-14-2009, 10:53 PM #11
04-14-2009, 11:07 PM #12
04-15-2009, 01:48 AM #13I have a need for speed!
- Dec 2006
- Standish,Maine
Putting in any thermostat, not "that thermostat", may have been the cause. Maybe you shouldn't have replaced the thermostat. Then again, it may have been coincidental. But don't listen to me, I've only been working on cars for 20+ years. My GM, and ASE certifications are just pieces of paper.
04-15-2009, 05:37 AM #14
I was reading on advance auto's website and if their warrantied parts causes a problem they will pay the fees to fix it if you have the receipt....probably have to go through a lot of bs to get money from them i bet.
04-15-2009, 06:33 AM #15
04-15-2009, 08:27 AM #16
sorry to say it bud, but wrong part or not you installed it not the parts store. Also like jigger said it could also be completely coincidental. The GM 6 cylinders love to eat intake gaskets. The one on my Blazer is leaking as we speak (...well type). GL man.
04-15-2009, 12:23 PM #17
make em pay!!! they are liable!!
04-15-2009, 07:39 PM #18
04-16-2009, 02:58 AM #19
Question: what should i make?
By 02_slp_ss in forum General HelpReplies: 9Last Post: 11-01-2010, 07:53 AM -
How much do you make?
By 2tuff4u in forum Firebird / WS6Replies: 83Last Post: 10-10-2009, 03:17 PM -
You can't even make this up!!!!
By blackSS01 in forum Almost Anything GoesReplies: 44Last Post: 07-23-2009, 09:19 PM -
You can't even make this up II!!!!!!!!
By blackSS01 in forum Almost Anything GoesReplies: 20Last Post: 07-23-2009, 06:42 AM -
Who wants to help out and make a new...
By Bigrus in forum Almost Anything GoesReplies: 29Last Post: 06-02-2006, 04:40 AM
2002 SLP Camaro SS
