Results 1 to 11 of 11
    Member turbojimmy's Avatar
    Feb 2007
    NJ
    2002 Trans Am Convertible
    Bass in a convertible?
    I'm the proud new owner of an '02 TA convertible. As you might imagine, the convertible configuration leaves a lot to be desired in the way of sound quality, particularly in the bass department. Has anyone come up with a way to get more bass out of the system without consuming what little trunk space there is? The stock system is pretty weak.
    TIA,
    Jim
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    I had to remove the spare tire and add a 12" JL
    Forged 383 | ATI D-1SC
    NX MAF Kit | 222/226 .585 115
    AS Stage II 6.0L FI Heads
    Feb 2007
    NJ
    Quote Originally Posted by Ed Blown Vert View Post
    Hmmm. That's a bit radical for me since it's my daily driver. Where does the little bit of bass it does have come from? The front doors? There's no subs, like with the coupes, right?
    Jim
    LA
    Grey
    2010 Camaro 2SS/RS CGM
    pretty much your only option is a stealthbox in one of the side compartments, and unless you want to take out the motor for the convertible you will have to use the pass side. Thats about all the option you have for bass in a vert.
    Markeyse Jamar Mundy M-ManLA's Avatar
    Sylmar, California, United Sta
    Gray
    2000 Camaro GT Street V6
    +1 for the stealth box. You can put an 10" there.
    Dec 2008
    JolietIl
    SIlver
    2000 Z28 Camaro convertib
    I put a Blaupunkt THb 210A behind the passenger seat. Ran the RCA under the console and used the power and grounds (two of each) that powered the Monsoon amp. WORKS GREAT. If I park with the top down I just unplug the power & RCA and lock it in the trunk.
    For the most part with the back seat flipped down you can even see it. It will not piss off the guy next to you. But supplements the door panel Infinity's I have nicely.
    Feb 2007
    NJ
    Quote Originally Posted by skew View Post
    Thanks. Is there any advantage to upgrading the stock speakers first? I don't want a ton of bass, but a little more than the peaked-out stock speakers can provide.
    Jim
    Gainesville, VA
    Quote Originally Posted by turbojimmy View Post
    Jim
    I upgraded the speakers in my vert and it was a night and day difference. I'd really like to add some bass too but space is so limited I have not done so. I think eventually I may just put a tube in my trunk.
    Feb 2007
    NJ
    Quote Originally Posted by rc74racer View Post
    I think I'll do that first. Thanks.
    Jim
    Gray
    If you want something that is better than stock but you don't want a sub, you can just upgrade your stereo and speakers. I would suggest getting dynamat though.
    Gainesville, VA
    Jim
    After I replaced the speakers I changed out the head unit and added a 250 watt 4way to power the replacements this too made a nice improvement in sound. Like I said bass still lacks but it sounds great.
  1. What happened to my bass?
    By 5abivt in forum Stereo and Electronics
    Last Post: 07-20-2011, 09:32 PM
  2. Question: Bass Blockers
    By CaptainCaveMan in forum Stereo and Electronics
    Last Post: 03-24-2009, 03:00 PM
  3. Adding Bass to an 06 GTO
    By PatrizioD in forum Stereo and Electronics
    Last Post: 12-29-2007, 01:32 PM
  4. No bass after HU swap... wtf?
    By Vrbas in forum Stereo and Electronics
    Last Post: 07-10-2007, 09:49 AM
