    SE PA
    2000 SS vert
    Not your typical gear question.
    Hey everybody...thanks for your help in advance. I have a 2000 SS M6, 130,000miles. Its time to change the bearings, both the axle bearings and pinion bearings need to go...the whine is real bad. Fortunately, a buddy of mine has been building his own and rebuilding rears for 20 years now, and he's gonna take care of it for me. He tells me since he's replacing all the bearings, its best to get new r&p while he's in there, so that all the parts "set" together. This is fine w/ me b/c he is gving me the gears for really really cheap (they are new and are high quality).
    I have searched on this forum all the comments on what gears to get. I am not a track guy, just a daily driver that does like to get on it here and there. So I will stick w/ the 10 bolt. I'd like to get lower gears for some oomph since I'm in there anyway. I see that most M6 guys on here recommend 4.10, but I don't know if that is b/c these are mostly dragstip guys and that is what is best for the track? I haven't seen any posts buy DD guys who just want some more power for occasional showing off on the street.
    Is going from 3.42 to 3.73 even worth it? What about 3.90?
    Will the lower the gear increase my chance at breakage? What do you think? It is mostly stock w/ SLP exhaust and cold air kit, and will likely stay that way.
    Thanks everybody.
    Senior Member Bottesini's Avatar
    Denton, Texas soon Lafayette, Louisiana
    Blue
    2002 Z28 Camaro M6
    I have 4.11s in mine and it is defiantly my daily driver. Honestly, they work out just fine for me. In town I just use a higher gear and skip gears a little more than I did with the stock gearing. On the highway I just tend to run at 75 mph instead of 80 since the car sounds happier running at 2100 RPM. Personally, I love having the acceleration of 4.11s, just be careful on wet days
    Euclid,ohio
    1998 Z28
    do the 4.10s'. You'll also need a computer adjustment to correct your speedo,but that'll also be needed whatever gear ratio change you make.
    SE PA
    2000 SS vert
    thanks...will lower gears increase my chances of breaking? thats my biggest concern
    Blue
    2002 Z28 Camaro M6
    Quote Originally Posted by harleySS View Post
    Yes and no, if you never run a sticky tire than you should be safe. If you put a sticky tire on than you will most likely break something if you abuse it. In general, I have found that they don't break as easily (best brand was GM). They will also help keep your clutch and tranny from breaking as easily.
    Member TA98's Avatar
    Mar 2009
    Maryland
    If you dont drop the clutch from 5 grand you shoulnt break anything.
    Auto Painter RyanJM's Avatar
    Houston, TX
    I run 3.73's in a A4 so a 4.10 will be fine. I was going at least 4.10's when I do the 6spd swap. I beat on my car and the rears break because there junk. If you don't beat it too bad or run DR's or slicks you should be ok. I plan on a 9" next time it breaks.
    1998 Trans Am 85k miles.
    02 Trailblazer -Sold
    09 Ram 1500 CC - Sold
    09 Cobalt SS/TC - Sold
    🤔 11s. blackbirdbrain89's Avatar
    hagerstown, mercersburg
    black trans am
    2000
    ok i have had 3.42 stock, a set of 3.73 and im runing 3.89 gears in my nine inch now note i use my ta as my dd.... 3.73 are not bad on gas and u will fell a diffrence in the car... now i have 3.89s and on street tires it to hard to keep the tires from spining but im a bolt one car... allk in all i got 28-30 on the high way if u drive nice and easy i hope that helps
  1. 3:73 gear question
    By Pickle86 in forum Drivetrain
    Last Post: 02-17-2010, 02:29 PM
  2. The typical question.
    By Black95Z28 in forum External Engine
    Last Post: 11-11-2008, 04:45 PM
  3. Gear Question
    By 98formy in forum Drivetrain
    Last Post: 05-24-2007, 12:26 PM
  4. Gear Question
    By christianjax in forum Firebird / WS6
    Last Post: 11-15-2006, 11:47 AM
  5. Gear Question
    By rbrack in forum Drivetrain
    Last Post: 10-06-2006, 06:39 AM
