Thread: help needed
    Apr 2009
    roanoke, va
    01 z-28
    help needed
    Hello all! I got a couple of issues with my car and wanted to see if anyone had the same problems or if they mat have any ideas whats up. 1) when I turn at about 5-15mph I get kind of a whining sound(kind of low toned) from the rear. I have new 3.73 gears and bearings in it. The noise hase been there since I have owned the car. Ok #2) just recently installed shift kit and 2500 tci stall, but I am get a grinding noise at low rpm's, and sometimes a lil slipping sensation. This is an automatic car. Ok #3) I have changed air box and maf but thinking of upgrading throttle body and intake manifold. Any suggestions to what brands or size upgrades to do. I do have programmer so can change my mixtures and spark. And lastly #4) has anyone else had trouble with the marker light on the driver side keep blowing. I have chased the wires, and no bare spots, have changed sockets out, and still blows it.
    Stang Killer TransAmFanatic's Avatar
    Feb 2008
    Harvey, La
    1999 Trans Am
    you should get an LS6 intake, and as for the turn signal do you get water in it? if so then you might want to change the housing for it, or you might be using the wrong bulb in the socket. the whining you hear from the gears thats just what happens when you change the gears. i have the same problem. probably need the check the shims in the rear end.
    Nov 2008
    harrisburg pa.
    02 vette vert
    just checking on the simple stuff, are you using the limited slip addiditive in the rear end? if not you could have noise when turning, especially noticable at low speeds. a gear or shim problem should be noticable all the time. this sounds like the clutches when they dont have their special juice.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Quote Originally Posted by TransAmFanatic View Post
    Looks like he has an 2001...so he already has the LS6 intake
  1. Question: help needed
    By 2000ls1tranz in forum Suspension and Handling
    Last Post: 09-08-2010, 03:21 PM
  2. LS1 needed
    By 1998 T/A in forum Parts Wanted / Trade
    Last Post: 07-29-2010, 10:38 AM
  3. Help needed
    By Ajp7987 in forum General Help
    Last Post: 09-14-2006, 01:41 PM
  4. Much Help Needed!!!!
    By fuelslut in forum Internal Engine
    Last Post: 01-14-2006, 06:47 PM
