Thread: Bolt Stretch
04-08-2009, 08:26 PM #1Junior Member
- Nov 2008
Red- 1998 Camaro Z28
Bolt Stretch
Has anyone ever used a bolt stretch gauge while installing arp rod bolts? Im am attempting to do so now, but i can only tighten the bolt about half of what it is supposed to stretch until it becomes too difficult. I could put a pipe on the end of the wrench, but is it normal for so much force to be required? I am afraid of over tightening.
04-08-2009, 08:57 PM #2
installing stretch bolts requires a dual readout torque wrench. I dont know much but i hope this helps
04-08-2009, 10:14 PM #3your parts guy!!!
- cleveland ohio
trans am 00 ws6- 1998 camaro ss vert
i'm pretty sure it is 400 lbs.
just checked.
book says 240 first pass. second pass 37 more,
04-10-2009, 10:04 AM #4
I believe you mean degrees and not lbs right?
The write up I saw used Katech bolts and they were torqued like 3 seperate times. Their search function sucks now so I can't find the thread but I *think* it was like 30-30-50 ft/lbs for the katechs. Call ARP and see what they recommend and go with that.
04-10-2009, 11:53 AM #5Junior Member
- Nov 2008
Well when you are measuring stretch alone, it is a little different. The guage tells you how much the bolt is elongating by, and all you use to do the tightening is a boxed end wrench.
04-12-2009, 09:06 PM #6Junior Member
- Mar 2008
- ohio
Yellow- 2004 Pontiac GTO
I have done it. I used a Comp Cams rod bolt stretch gauge.
1) How are you trying to do it?
2) Do you know how to read a dial indicator?
3) Are you using the moly lube that came with the bolts? YOU MUST USE THE MOLY LUBE THAT CAME WITH THE BOLTS!
Every time I did others. I turned the rod bolt down untill it just touched the rod and then zeroed the stretch guage on the bolt. I used a torque wrench and torqued them to 40lbs and then loosened them up, then torqued them down to 40lbs again and then loosened, and then one more time to 40lbs and then loosened them up.
I would then check the bolt, and see if it had the proper stretch on it, in between .0062-.0067.... If not I would loosen it up all of the way, and then use a wrench untill I got the proper stretch.
College Football Home stretch
By skar in forum Almost Anything GoesReplies: 123Last Post: 12-04-2007, 05:44 PM -
Corvette Torque Tube Stretch
By Z06chevelle in forum DrivetrainReplies: 0Last Post: 10-01-2007, 08:20 PM -
Center bolt to Perimeter bolt Heads, Coil Mounting help
By juiced99ws6 in forum Internal EngineReplies: 7Last Post: 03-30-2007, 11:38 PM
