    Junior Member CobraKilla's Avatar
    Monroe,Michigan
    2000 TA LS1 A4w/ShiftKit
    Parking Light a Closed unit or Bulb on a 00' TA
    One of my parking lights is out and the other is dim with the headlight knob turned in the off position. When I click it to Parking light only position the one that was not working comes on dim and the other is twice as bright as it was before when the headlight knob was turned off. So my question is: Is the Parking light a two way bulb or is it a closed unit ?
    Member 346ci's Avatar
    AK
    1998 Z-28
    Not sure what you mean by closed unit and two way, but it sounds like you have a grounding issue. There is a separate ground for each side that is located on top of the radiator support, I'd check to make sure they are clean and tight.
    Monroe,Michigan
    Quote Originally Posted by 346ci View Post
    Is it jus a bulb that has to be changed or is it the whole fixture. I just noticed it tonight and didnt want to dive into it in the dark just was curious. But I will check out the grounds. The 2 way I asked about I should of been more clear is there a dim and bright in the parking light ?
    AK
    1998 Z-28
    They are replaceable bulbs and only one stage (on or off)
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    The driving lights are two stage two fillament.
  1. Question: Dial light bulb
    By blackws61999 in forum Stereo and Electronics
    Last Post: 05-23-2009, 07:00 AM
  2. fog light bulb
    By 1MileCrash in forum Camaro / SS
    Last Post: 04-07-2009, 05:14 PM
  3. fog light bulb??
    By ws6race in forum Appearance Section
    Last Post: 03-27-2009, 03:37 AM
  4. Light bulb #
    By JoshieDoom in forum General Help
    Last Post: 11-08-2008, 01:30 PM
  5. Trans Am front parking light bulb socket
    By sk8runeg in forum Parts Wanted / Trade
    Last Post: 03-17-2006, 05:25 AM
