Thread: optima yellow top correct size
04-07-2009, 04:44 PM #1
ok the optima sie calls for a 75/25 for my 2001 camaro ss but i see many people with a 34/78... which is the correct one, will i have to do any mdos to get either olne to fit??? Thanks
2001 Camaro SS T-56, ATI PROCHARGER D1SC with dual intercoolers, 4.25 pulley, walbro 340 fuel pump, 60lb Siemens fuel injectors, ATI Super Damper, Pacesetter LT Headers, Texas Rumbler X True Duals, Spec Stage 3+, UMI Subframe Connectors, Motive 4.10 gears, Alterstart 200 amp Load Boss
04-07-2009, 05:11 PM #2
Both the 75 series and 78 series should fit your car no problem.
I would go with the 75 series though, since it has the properly spaced side terminals. Both are also dual post (top and side), which makes jumping and charging much easier.
04-08-2009, 12:00 PM #3
anyone else? will both batteries mount using the stock mounts???
04-08-2009, 02:00 PM #4
04-09-2009, 09:07 AM #5
Thanks again!!!!!!!!!!!
Yellow Top Optima Battery
By redfiress08 in forum Stereo and ElectronicsReplies: 2Last Post: 06-07-2008, 02:53 PM -
defective yellow optima battery. anyone had same ?
By Eugenio_SS in forum Stereo and ElectronicsReplies: 7Last Post: 05-29-2008, 09:38 PM -
Yellow top or Red top optima?
By GetSome04 in forum GTOReplies: 20Last Post: 01-01-2008, 06:46 PM -
optima yellow top
By dcamcotii in forum Stereo and ElectronicsReplies: 0Last Post: 06-26-2006, 01:25 PM -
Optima Yellow Top Battery
By Ed Blown Vert in forum Western MembersReplies: 19Last Post: 09-28-2005, 01:40 PM
