Results 1 to 3 of 3
    38 of 139 PontiacFan's Avatar
    Kearney, NE
    6 (100%)
    2001 Pontiac
    TCI Streetfighter Torque Converter
    (Tried to edit my other sale ad, but it won't save the thread title changes.)
    I have a used TCI #242931 Torque Converter up for sale.
    $360 plus shipping (New is $450-500+ depending on vendor.)
    (Package is 14"x13"x8" & about 35pounds, from 68847 for those who want to calculate shipping.)
    I bought it used last year, but have not had time to do any install. I'm looking to change up to a higher stall unit, so this one has to go. According the seller I purchased it from, it was only in the car for a couple thousand miles before he sold the car. I have no other information that what is shown here.
    TCI builds more converters than anyone else in the industry & this one is sure to please any new potential new user.
    Info below is simply stuff I've copied from one of TCI's auction listings.
    TCI STREETFIGHTER TORQUE CONVERTER #242931 FOR 1998-up GM 4L60E F-body LS1/LS2 applications; 1999-up GM 4L60E/4L65E trucks w/ 4.8, 5.3, 6.0 engines
    StreetFighter ®
    Designed with the street racer in mind, this torque converter benefits more radically prepared street machines (those with performance cams, aftermarket carbs and higher compression ratios) to bring the launch rpm in line with the performance enhancements. The StreetFighter® lets you take advantage of horsepower gains found in highrer rpm ranges.
    Key Features:
    Furnace-brazed fins
    Needle bearings
    Hardened, pre-ground pump hub
    Computer Balanced
    Triple Tested Quality
    TCI® strives to produce the best torque converters in the industry. Part of the process involves ensuring that each unit is built to spec. Regardless of what category or price level it may fall into, every TCI® torque converter is Triple Tested during assembly.
    Once all the prep work on the component parts has been completed, the impeller is welded to the front cover. Immediately following this process, a pair of dial indicators are employed on a rotating table to verify that the impeller body and pump drive hub remain true.
    Each unit is then pressurized and subjected to a leak test to confirm the integrity of all the weld seams. Lastly, each unit is computer balanced to reduce annoying and potentially damaging drivetrain vibrations that would occur from an unbalanced torque converter. That's Triple Tested so you can be confident you're getting a torque converter that's ready to roll.
    Specifications:
    FLASH STALL
    ANTI-BALLOONING PLATE
    DIAMETER
    FURNACE BRAZED
    BALANCED
    3000-3500 RPM
    10.00 INCHES
    tampa
    1998 firebird
    lock up?
    Kearney, NE
    6 (100%)
    2001 Pontiac
    Quote Originally Posted by shaolink9 View Post
    lock up?
    Yes it is.
    Seriously interested potential buyers should PM for info if I don't respond too quickly.
    ttt, for price reduction, ...
  1. Best Torque Converter?
    By Rich L in forum Automatic Transmission
    Last Post: 09-20-2008, 03:26 AM
  2. FS: TCI streetfighter LS1 fbody 98-00 converter
    By lukasink in forum Parts For Sale / Trade
    Last Post: 12-19-2006, 06:17 AM
  3. Replies: 2
    Last Post: 09-21-2006, 09:56 AM
  4. wtb a torque converter for my 94 z28
    By jamilz28 in forum Parts Wanted / Trade
    Last Post: 04-22-2006, 06:55 AM
  5. streetfighter stall converter
    By nhraformula in forum Parts Review
    Last Post: 08-05-2005, 06:34 PM
