Results 1 to 3 of 3
Thread: Reverse Switch?
04-05-2009, 11:50 AM #111 years of bangin gears
- Jan 2009
- North Jersey
Reverse Switch?
OK. A month after I bought my GTO it started blowing fuses for the hazard and turn signal. I noticed my L/F sidemarker bulb popped. I replaced the bulb and all was good for a year...until last Friday. My car started blowin the turn signal and hazard fuse AGAIN! I have been outside all morning today trying to find out what was causing the short. I typed in the issue and gave me a link to another GTO forum I was a member of and the threads. Someone also had the problem but after they installed a V1 radar detector. I saw the pic and noticed a wire. I had the same wire and I pulled it out. The previous owner had a hardwired detector and possibly an I-Pod interface along with a special harness running from the car harness to the T/C to run the detector and the harness has burn marks like something was shorted. I replaced both turn signal and hazard fuses and turned the car on and hit the left turn signal and popped the turn signal fuse, I then hit the hazards and THAT fuse went. I had left the car in reverse and when the turn signal fuse went, my backups went out.
So I can assume the reverse lights are run off the signals and the hazards and the reverse switch is toast?
04-06-2009, 03:42 AM #211 years of bangin gears
- Jan 2009
- North Jersey
Welp, threw the Goat on the lift and disconnected the reverse switch and put in ANOTHER fuse and my signals work. I didn't think the GTO was wired like an F-Body. Who knew...?
04-07-2009, 02:54 PM #311 years of bangin gears
- Jan 2009
- North Jersey
OK mods...just puttin this out here. GM/Delco part #14069600. Don't know it the FBodies use the same reverse switch, but I figured the mod staff would sticky this for future reference...if it hasn't been added already.
ALSO...I think the harness that was connected to the T/C is a skip-shift eliminator. So I guess I had TWO skip-shift eliminators? The one connected to the T/C and the one downloaded from HPTuners? Why do I have this feeling I may have the SLP Bobcat 421 package? I dunno.
Reverse Light Switch
By GatorSS in forum General HelpReplies: 3Last Post: 01-07-2015, 07:29 AM -
Park/Reverse/Neutral Switch
By Badass WS6 in forum General HelpReplies: 1Last Post: 08-04-2013, 06:34 PM -
Help quick! Changing reverse switch...
By Firebird Phoenix in forum General HelpReplies: 5Last Post: 05-30-2008, 10:39 AM -
Traction control reverse switch
By timowen1 in forum Firebird / WS6Replies: 5Last Post: 02-22-2006, 01:57 PM -
HELP!! Reverse Light Switch
By 99WS6MAN in forum General HelpReplies: 3Last Post: 02-10-2006, 08:06 PM
