Results 1 to 20 of 27
Thread: tranny cooler
    Member c5z28's Avatar
    Bay Area
    On your ass flashing
    my highbeams
    tranny cooler
    I'm going on a cruise next weekend through the hills and I have a feeling I will be in 2nd gear alot I heard b&m tranny coolers were the way to go what did you guys get, and did they come w/ all the plumbing you need?
    Senior Member SS02's Avatar
    None
    My old friend had a B&M in his 4 drive truck and installed it
    in one afternoon... I was not there, in time to help. He did
    it fast and never had any issues.
    My SS came loaded with one so I cannot help anymore
    then this.
    Bay Area
    my highbeams
    I figured it was easy enough, at least I know everyone uses b&m
    None
    I will call my friend on saturday(today) and ask about if it came with
    all plumbing/fittings? I bet U can order a full kit!!!!!!!!!!!!!!
    Bay Area
    my highbeams
    Quote Originally Posted by SS02 View Post
    I'm sure of it I went on ebay and I got a wave of tranny coolers, they all looked different w/ different prices it was freakin overwhelming. Thanks for the info and the call to your buddy it all helps my tranny stay alive
    Awaiting Activation lovedrvr's Avatar
    west kentucky
    1999 z28
    this is what ya want
    http://store.summitracing.com/partde...part=BMM-70264
    took me a 1/2 hour to install,you need 1 extra hose clamp
    put mine sideways over the left fan on the out front run the clips through the rad,hook up to the line that has the clamp on it
    Bay Area
    my highbeams
    Thanks kind of hard finding room down there
    Senior Member clg82's Avatar
    Feb 2007
    California
    2000 Trans Am
    Quote Originally Posted by lovedrvr View Post
    I plan on purchasing a 3600 Stall will this do me good for the stall or should I get bigger?
    Bay Area
    my highbeams
    bigger is always better
    Junior Member silversho89's Avatar
    Jan 2008
    Just outside of St. Louis
    pewter
    2001 Z28
    Is the stock cooler an external or does it run in the rad like some cars? Also, can i run both coolers in series for even more added cooling?
    Thanks,
    Rob
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Quote Originally Posted by silversho89 View Post
    Thanks,
    Rob
    Stock runs to the radiator. You can run them in series but most likely it would do negative work.. EX... it would be heated up by the coolant.
    Jan 2008
    pewter
    2001 Z28
    Gotcha. Guess i could always run a bigger cooler. Isn't it 210*F that the tranny starts to have shit overcooking?
    Feb 2007
    California
    2000 Trans Am
    I guess what i meant to ask is will this be suffecient for my 3600 stall that i plan on installing???
    Beaver Dam KY
    79 T/A -91 Firebird
    Performabuilt said right around 245 is starting to get scary if i remember correctly. I can beat on mine and go and touch the cooler and its not very hott at all
    Feb 2007
    California
    2000 Trans Am
    ^^^anyone???
    Broken Arrow, Ok
    2000 Z28
    ^^^anyone???
    It would work fine IMO. I dont know what GVW weight that cooler handles. I bought mine from Texas Speed 7 years ago.
    http://www.texas-speed.com/shop/item...d=392&catid=58
    I also bought a Hi/Low fan switch. When in traffic that is not moving I can turn the fans on to help cool the tranny.
    http://www.speedinc.com/cont.cfm?cid=C0000100
    The cooler should be bought at the same time as the stall. It should be put on at the same time also. I would also think of getting a deeper pan. I did not buy the one I am showing you just showing you what it looks like. GM trucks have the deeper pan. I went to a junkyard and got one for 5 dollars.
    http://www.speedinc.com/cont.cfm?cid=C0000129
    Heat kills automatic transmissions. All of the above will help keep the heat out. And when it gets really bad turn on your fans.
    west kentucky
    1999 z28
    you will be fine with this cooler and the stall,hook it up to the line that has the clamp in series,the rad is a pre cool, then it goes through the supercooler
    Feb 2007
    California
    2000 Trans Am
    Does the cooler that you listed from texas speed come with all the fittings, hose etc etc etc........
    Feb 2006
    2002 WS6
    Nope, run it through the stock cooler, then out of that to the aux cooler, then back to the tranny, tranny fluid will be way warmer then the water in the Rad.
    Broken Arrow, Ok
    2000 Z28
    Yes it comes with everything needed to install it.
  1. B4C comes with tranny cooler is that enough
    By Z28boy2000 in forum Automatic Transmission
    Last Post: 11-03-2009, 05:03 PM
  2. Question: Best tranny cooler to buy?
    By clg82 in forum Automatic Transmission
    Last Post: 04-05-2009, 03:38 PM
  3. tranny overheating, need bigger tranny cooler?
    By djvaly in forum Drivetrain
    Last Post: 03-22-2007, 03:25 PM
  4. tranny cooler for m6?
    By third_shift|studios in forum Manual Transmission
    Last Post: 10-11-2006, 09:00 AM
  5. Tranny Cooler
    By easyericvan in forum Drivetrain
    Last Post: 01-02-2006, 06:06 PM
