Results 1 to 10 of 10
01-24-2006, 03:43 PM #1
Critique my mod dream list please!!
At the present time I own a 98 WS6 with about 51k miles (as seen in my avitar). Iv comprised a mod list and done it in phases in which Id like to do it. Im not familiar with superchargers enough to feel comfortable as to what kind of supporting mods or what order to mod to be most proficient and not having to go back and do things over again. So here is how I have it arranged. Id like some feedback in the order and type of mods I should do.
Phase I
Moser Engineering 12 bolt rear w/4.10's
BFG Drag Radials
Hooker LT headers and y-pipe
Sub Frame Connectors
Tubular upper and lower A-arms (spohn)
Tubular K-member (BMR)
Panhard Bar (spohn)
Adjustable Lower Control Arms (spohn)
Adjustable Torque arm (spohn)
Pro Series Rear Sway bar (spohn)
K&N/NGK's/Wires/Bellows/SLP air lid
Full QA1 suspension package (springs, shocks)
(Apx $7,000)
Phase II
ATI Procharger D-1sc 6-8lbs
T-rex inline fuel pump
42lb injectors
Upgraded fuel rails/steel braided fuel lines
Stage 3 clutch
Fast LSX Intake Manifold
Dyno Tuning
(Apx $7,000)
Phase III
Up boost to 12-15lbs
DR Evil Rebuilt T-56 Tranny
Head porting/new valves
Cam specs???
Internals ???
Heavy duty driveshaft
Dyno tuning
Stage 4 clutch
($not really sure need input)
I need ideas!!!!! HELP!!Last edited by Capster78; 01-24-2006 at 04:05 PM.
01-24-2006, 03:57 PM #2Dreamin of a Paint Job...
- Sep 2005
- Alabama
Silver- 2000 WS6 Trans Am
i would personally move the rear end to phase 2. Do suspension mods, bolt ons, cam, long tubes first. Then go ahead and get it dyno tuned.
01-24-2006, 04:03 PM #3
I thought about that but then again Im affraid to have all that suspension work on DR's cuting 1.6 60fts on a stock rear end (M6). It would be hard to afford the supercharger and the rear end all at the same time.
01-24-2006, 04:20 PM #4
did you just accidently shit 14,000 dollars, because if so i would like to know what you ate
01-25-2006, 02:49 AM #5I agree on this 100% great list but you might want to rethink the order a little.
Originally Posted by XtinKt
by the way are your stationed @ sheppard. if so what do you do up there?
Went through tech school there about 5 yrs ago now @Dyess
01-25-2006, 09:20 AM #6You can always hold off on the DR's until you can afford the rear end. Without traction, you shouldn't break the stock rear.
Originally Posted by Capster78
IMO, you may be just as well off to build the internals of the motor first, select your heads and cam based on the boost level you want to attain later and then have it tuned. Then, when you can afford the supercharger and supporting items to reach your goals, intall it and have it tuned for good. That way, you shouldn't have to buy multiple blower drives and pulleys.
PS - I also want to know what you ate
Hammer - hammertime.us
2001 Light Pewter Metallic Camaro SS, 6 speed
K&N, SLP Lid, SLP y-pipe, GMMG cat-back, Lou's Short Stick - more to come!
01-25-2006, 05:10 PM #7
Yeah, but I still cant afford the supercharger and rear end at the same time. That would be 7k not including tuning and everything else I had on that list. Im trying to evenly space out the cost as well as do the mods in some logical type of order. From what I have read Im not going to need anything in the way of internal work besides maybe hardend pushrods for the supercharger at 8psi. I figured id leave all the motor work when I pushed passed the safe zone for the stock internals/fuel system I dont see the point in buyng nearly 7k in suspension and have stock tires on the back.. So I figured if Im going to spend the money on a bunch of suspension parts (which IMO should be the first thing you do before you add more power) I should have a 12 bolt under there so I could actually make use of them.
Im not going to come up with 14k all at once. Thats why its broken up. When I get back from my tour in Korea I should have atleast 7k saved up to buy the parts ill need for the first phase of mods. Im only an A1C but I have car/insurance and that is it for bills. All the rest goes in my pocket.
Keep the opinions coming though.. Thanks!!
01-26-2006, 12:21 AM #8
01-27-2006, 04:40 PM #9
No, Im in Avionics. I work on just about any kind of aircraft.
01-27-2006, 07:39 PM #10Slow'er'Ass
- Thornton, CO
This is very subjective.
Originally Posted by hammertime
I know two guys that have broke the stock rear on street tires.
That is most likely my next mod....because I have a feeling mine is toast this spring.
Lowered, HID's, tinted.
Critique my custom fabbed exhaust merge
By Hi-Po in forum External EngineReplies: 5Last Post: 02-28-2010, 08:33 AM -
Critique my soon to be facebook status
By 86 IROC-Z in forum Almost Anything GoesReplies: 262Last Post: 10-05-2009, 11:49 AM -
Critique my exhaust setup !
By 5abivt in forum External EngineReplies: 2Last Post: 05-19-2009, 09:59 AM -
Please critique these headers
By scv8 in forum External EngineReplies: 6Last Post: 12-17-2008, 07:21 PM -
critique my rant
By Modulistic in forum Almost Anything GoesReplies: 36Last Post: 07-03-2006, 08:38 PM
