Results 1 to 20 of 25
Thread: Guess my HP?
04-02-2009, 07:21 PM #1
Guess my HP?
With mods in sig and these mods, anyone care to guess what I will put down. Just want to get a general idea, I know dyno's vary and weather and all that other stuff change it but want a rough idea.
LS6 Ported, Polished, clean up mill (64CC)
Comp 918 springs
LS7 lifters
LS2 lifter trays (with half inch hole drilled in them)
Hardened Pushrods
Torquer V2 camshaft (232/234 .595/.598 112LSA)
LS6 ported oil pump
LS2 timing chain
I was guessing around 430rwhp but have no clue. Anyone else?┌∩┐(◕_◕)┌∩┐
wouldn't want to fight them!
04-02-2009, 07:42 PM #2Awaiting Activation
- Jun 2008
- Decatur Al
NBM- 99 Z28
I'll take a stab at it and say around 400-410.
04-02-2009, 07:49 PM #3
That seems really low. I would think I would be close to 400 with just the cam. Cam advertises 45-50 rwhp gain. Thanks for posting tho.
04-02-2009, 08:06 PM #4Awaiting Activation
- Jun 2008
- Decatur Al
NBM- 99 Z28
you might get 430 I don't believe a cam alone any cam is good for 45 to 50 hp, but you do have good heads its gotta work as a combo. I don't know alot about heads and cams power numbers just taking a wild guess at it When you getting it dynoed?
04-02-2009, 08:09 PM #5
I tend to be sceptical about advertising on parts. So the 45-50 rwhp, I am not putting too much thought into that. I will be getting it dynoed around June, when its done
I have everything ready to go except
Cam
Oil Pump
Timing Chain
Head bolts
Other then that, its ready to rock.
04-02-2009, 08:25 PM #6Awaiting Activation
- Jun 2008
- Decatur Al
NBM- 99 Z28
Cool man, keep us posted.
04-02-2009, 08:29 PM #7
Not a prob
Anyone else with a set up like this that can chime in
04-02-2009, 11:53 PM #8
Those heads are 64cc stock, but you say they are milled? Why not take them down farther?
I'd expect 415-420 with the LS6 intake.
04-03-2009, 02:08 AM #9
I'd guess between 430-440rwhp.
04-03-2009, 02:43 AM #10
Go get your car dynoed and see who had the best guess.
04-03-2009, 08:26 AM #11
They are 64.45 CC to be exact (at least what I have discovered) so the clean up took them to 64 CC on the dot. I would have took more off but didn't want to run into PTV issues with the Torquer V2 and the longer valves. And I forgot to mention that I will have a Frost Tune also until I can do a dyno tune after the rear end and such (EWP/Fast 90/90) So Frost, you should be seeing the PCM soon.
04-03-2009, 02:26 PM #12
i guess 440.
04-03-2009, 02:29 PM #13
435hp and 417 tq
04-03-2009, 02:52 PM #14TJEA Retirement Home
- Feb 2006
- U. S And A Greatest country in all of world
Stock- 2002 Camaro
check out what i made. close to your set-up. less cam but more heads.
EDIT: i guess i should put that they are stage 2 patriot heads 59CCLast edited by Dr.Crash; 04-03-2009 at 03:00 PM.
02 SS
LQ9 408 Stroker ,M6 1LE, LT's, ORY, GMMG, STG2 LS6 heads,248/254 .612/.622, Tubular LCA's, Panhard, torque arm, tranny cross-member, upper and lower a-arms, k-member, 3 point SFC's, Baer 6 pistons up-front, stock rear
, Adj. coil-overs,
12.6@120MPH
81 Celica
18.1 @ 85MPH
04-03-2009, 03:38 PM #15
no more than 410rwhp/390rwtq or so...
2013 ZL1: °°590rwhp/576rwtq°°
04-03-2009, 05:03 PM #16
Alot of different guesses. Wish it was done so I could put that bitch on and see what it pulls, time will tell. I will post ASAP as soon as I do
04-03-2009, 05:40 PM #17
I would have at least gone to 62cc.. I really don't like that cam. After hundreds of cars, that cam consistently seems to take more time to get to idle and drive than any of other 'popular' grinds, including the upper end of the spectrum duration-wise. To be honest, this setup is a little outside of the honest intent of mail order tuning as well. I'm not saying I can't help you out...t PM me and I'll shoot you my number and we can speak about it on Monday.
04-03-2009, 05:56 PM #18
04-03-2009, 11:41 PM #19515 HP TrickFlow Package
- Feb 2008
- Palm Beach, FL
440 RWHP / 410 TQ- 2000 SLP CAMARO SS
I am going to go with 435 RWHP / 415 TQ. Good luck, and I hope it is more closer to the 450's!
04-04-2009, 05:35 AM #20
So what would your guess be?
By 35th-ANV-SS in forum Drag RacingReplies: 8Last Post: 08-16-2009, 12:01 PM -
Guess what I Saw a bit ago
By 98formy in forum Almost Anything GoesReplies: 5Last Post: 06-12-2009, 12:04 PM -
Guess what?
By grandkodiak in forum Almost Anything GoesReplies: 1Last Post: 03-24-2008, 08:16 PM -
HP Guess?
By sharptransam in forum General HelpReplies: 3Last Post: 06-25-2007, 05:34 AM -
hp guess??????
By sunset_hawk in forum Firebird / WS6Replies: 26Last Post: 06-08-2007, 04:35 PM
