    Member anniversary30's Avatar
    Illinois
    White/Blue
    99 Trans Am
    4th gen f-body 12 bolt rearend
    KTRE 4th generation f-body rear end with torque arm mounting provision33 spline axlesThicker and longer wheel studs (will require machining of brake rotors)Motive 3.73 gearHeavy duty posiRelocation bracketsAluminum cover with bearing supportsPainted black with POR 15Has LS1 reluctor rings for ABS/traction control (4 channel) but may cause damage to passenger side wheel speed sensor, good rearend but may take a little work. $1400
    Richmond VA
    2 (100%)
    LS1.com Sponsor
    GM Tuner
    what work does it need; you don't really say
    Senior Member SS02's Avatar
    None
    I kinda was looking for the point myself?
    NW Chitown
    2002 WS6
    I actually went and looked at this axle. It is in fair condition. The aluminum cover has a little damage on the adjusting nuts (looks like they were ground down for some reason) and might not be able to be adjusted beyond where it is right now. The axles need new bearings installed on them as whoever pulled them off left the inner races pressed on while trying to pull the old ones off. Otherwise the axles are in fine condition, but obviously have some age on them.
    I had pics on my phone but deleted them after I bought my 9" axle... good luck with the sale though!
    -Eagle
    Illinois
    White/Blue
    99 Trans Am
    I'm not sure exactly what it would take to fix what ever it is tearing up the wheel speed sensor. Sorry guys, all I have is the info my shop gave me. I really don't know much about rearends . I went with a 9" and now am looking to sell this one. The info on my post plus what ever eagle told you is what I got. If you have an e-mail address I can send you pics of it.
  1. Bolt-In Rearend Buyers Guide - Bolt-In Rearends -
    Last Post: 08-25-2010, 02:40 AM
  2. Bolt-In Rearend Buyers Guide - Bolt-In Rearends -
    Last Post: 08-24-2010, 02:40 PM
  3. Question: 12 Bolt rearend
    By breathnitrous in forum Drivetrain
    Last Post: 05-16-2010, 06:46 PM
  4. 12 bolt performance rearend ?
    By joe'sls1 in forum Parts Wanted / Trade
    Last Post: 05-23-2006, 04:51 AM
