Thread: Rear tail lights
04-01-2009, 04:42 PM #1
Rear tail lights
Need to know how to buff out swirl marls and fine scratches. I have a PC and have not had mubh luck. Please make some recommondations on pads to use and polishing material.
Only 34K miles and still counting (that's from Sept '97)
04-01-2009, 09:37 PM #2Impounded
- Oct 2007
- Beaver Dam KY
I would use a foam pad plus plastX by meguiars
04-02-2009, 11:42 PM #3Junior Member
- Mar 2008
- USA
Use a foam pad and this 3M Perfect-It Foam Polishing Pad Glaze. this will make it easier to polish your tail light. Also this glaze is good for swirl marks.
__________________
If you ain't first your last!
dragdreams
04-30-2009, 11:13 PM #4
05-01-2009, 06:50 AM #5Sold: LS1 '85 El Camino
- Dec 2005
- Laurel, Maryland
Sell me your TA and I'l take care of them
05-06-2009, 05:27 AM #6Senior Member
- Oct 2007
- Muncie, IN
00 TA PWTR, 98 VertTA NBM- 80 TA BLK, 80 Formula NBM
3m plastic polish
05-09-2009, 11:24 AM #7
if your having a hard time removing them, then do this:
wet sand with 2000 grit(dont be afraid, really get in there), this should remove all fine scratching and leave the plastic hazy, you can then use the 3m plastic polish or 3m rubbing compound(i do this by hand). then apply a nice wax.
they should look brand new after this if done properly.
05-09-2009, 08:33 PM #8
If you have a PC, you can get a 5.5" pads, or better yet, get a 3.5" backing plate and 4" pads for more leverage after you've wet sanded the area. Buffing alone would hardly do anithing on fine scratches...
LED tail lights for 4th Gen
By 2000dreambird in forum Appearance SectionReplies: 9Last Post: 06-02-2013, 10:15 AM -
98-02 Tail Lights
By nichoLaS1 in forum Parts Wanted / TradeReplies: 4Last Post: 10-18-2010, 11:46 AM -
Tail lights
By Ramairgod84 in forum Firebird / WS6Replies: 22Last Post: 01-05-2010, 08:43 AM -
Question: Tail LIghts
By TransAmFanatic in forum General HelpReplies: 15Last Post: 01-14-2009, 12:29 PM -
WTB- Tail lights for 01 Z28
By Twistingreality in forum Parts Wanted / TradeReplies: 7Last Post: 08-14-2007, 01:09 PM
