Results 1 to 20 of 26
Thread: slp under drive pulley
04-01-2009, 07:20 AM #1
is there actual gains to be had with this? worth the $200 or is it just another TB spacer....
04-01-2009, 01:11 PM #2
well it may free up 5-10 horse, but it will help your engine climb the RPM's faster is the biggest improvement....
04-01-2009, 01:16 PM #32000 Arctic White trans am, ws6 hood, ws6 air box, slp lid, slp smooth bellows, slp loudmouth exhaust,shift kit, rebuilt trans, LS6 intake, 3.73 gears, Shaner S3 p/p throttle body, and a tune . SFC. C6 ZO6 rims 18" in back 17" in front. Drilled and slotted rotors.
04-01-2009, 01:22 PM #4
they are relatively easy to install, you will just need a new GM crank bolt...
but what it does is puts a smaller pulley on the end of the crankshaft so the belt that runs all your accessories will turn slower, and with a smaller pully it will have more mechanical advantage, so it will slow it down some and turn the accessories like the Power steering pump, AC, Alt, waterpump easier...
04-01-2009, 01:28 PM #5
With my mod's will I notice a difference? and also how hard are they to install on a scale of 1-10? does anyone know where there is a write up on how to install one of these? and do you also have to buy new belts.....sheesh that's a lot of questions but every bit will help!!!
04-01-2009, 01:34 PM #6
A. Depends on how easily you notice things.....
B. 4
C. Somone correct me if im wrong, (I have not done it but follow me), set the motor at TDC on the stock pully, then remove the bolt holding it on, allign the underdrive as the stock one was and put new bolt in and torqe to spec....
D. You will use the same sized belt....
04-01-2009, 01:41 PM #7
ummm how do i find out where TDC IS??
04-01-2009, 01:43 PM #8
there are numbers on the pulley and a pointer on the block if it is normal... somone who has done this will step in, im just using basic knowledge and guestimating
04-01-2009, 05:45 PM #9
04-01-2009, 05:47 PM #10
I stand corrected....
elc you done this?
04-01-2009, 06:32 PM #11
04-01-2009, 06:37 PM #12
04-02-2009, 12:30 AM #13
Why would you need to TDC anything at all? LS1 cranks are not keyed and are internally balanced. That would mean all crank pulley's would be zero balanced. If it's zero balanced then you can put it on any way you want.
04-02-2009, 01:20 AM #14
Im not worried about balance, I was saying for purposes of when you need to find TDC for adjusting valves, cam install stuff like that. but i guess cam is set internally with timing chain, but just like wiht older motors where you had a distributer to adjust timing, you had to watch the numbers on the pulley..... but like i said, ours may not even have numbers all being computer controlled...
04-02-2009, 02:03 AM #15Member
- Oct 2007
- Macomb, Michigan
Black on Black- 2001 ~ T/A ~ WS6 ~ M6
Here's SLP's instructions from their website for 1998-02 LS1 Camaro/Firebirds:
http://www.slponline.com/inst/100221.pdf
Here's SLP's instructions from their website for 1997-2006 LS1/LS6/LS2 Corvettes:
http://www.slponline.com/inst/100225.pdf
There's some information in the page as well:
http://www.ls1howto.com/index.php?article=2
'I' personally have not performed this yet, but may in the near future.
04-02-2009, 02:46 AM #16
04-02-2009, 04:11 AM #17
Does anyone have the part number for the new bolt?
04-02-2009, 06:14 AM #18
04-02-2009, 08:37 AM #19
04-02-2009, 09:29 AM #20
BBK under drive pulley
By Too Fast in forum External EngineReplies: 3Last Post: 05-27-2014, 10:35 AM -
Under drive pulley?
By Edward-T in forum External EngineReplies: 12Last Post: 12-15-2011, 02:01 PM -
under drive pulley
By kappasig53 in forum External EngineReplies: 5Last Post: 06-09-2009, 08:07 PM -
March Under Drive Pulley
By 00 Z28 in forum External EngineReplies: 1Last Post: 03-14-2009, 02:30 PM -
under drive pulley are the worth it?
By NIKDSC5 in forum CorvetteReplies: 11Last Post: 03-23-2008, 09:59 AM
