Results 1 to 14 of 14
Thread: Spring cleaning
    Spring cleaning
    Car care 101 -- it took a lot of work to get our newest addition into shape. Everything looked pretty much original and with 71,000 miles, the undercarriage looked like it had not been cleaned since it left the factory. The wheel wells and suspension were pretty sad looking, but... after several evenings and a couple of weekends we went from this:
    To this:
    In addition to the cleanup -- also changed trans fluid and filter; replaced rear trans seal; replaced rear u-joint; flushed cooling system and replaced all hoses; new 180 degree thermostat; recalibrated fan settings; new belts; new sway bar bushings; sanded and polished curb rash on rims; and replaced the fuel filter. By far, the most challenging maintenance item was replacing the heater hose assembly -- lots of time and head scratching on that puzzle. Time to reinstate full coverage and go for the first ride of the season!
    Huge improvement
    Painted manta stripe
    Member onetroubledguy's Avatar
    Dallas, TX
    1999 Trans Am WS6
    Looks really good! I need to do the same to mine.
    Philly+Glenmoore, Pa
    Pewter Metallic
    2002 Trans Am WS6 M6 D1SC
    Awesome! Looks great!
    I did a little cleaning while I had my rim and wheel well off to take out the air pump but not as thorough as you. I need to take the time and really clean everything.
    What paint did you use for the center of the break rotor and spindle arm? What parts did you take off?
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Looks great man!!
    Member 346ci's Avatar
    AK
    1998 Z-28
    good job, wish I had the time/facilities to do that on my car
    Stockitie Stock Stock 95camaroZNC's Avatar
    Raleigh NC
    1999 Trans Am
    Def looks better then how it was before. Wish i had the time lol.
    Laurel, Maryland
    2000 Grand Prix GTP
    2000 Trans Am WS6 M6
    I used Caliper Paint, just because of the heat factor
    Thank you! The hub, rotor and bearing support are all POR -- degrease, wire brush and painted with a small foam brush. The upper and lower control arms and sway bar are Krylon semi-gloss black. The caliper is High Temp Cast Blast.
    The only parts removed were the sway bar, caliper bracket, and ABS harness. I also removed the wheel well liner and cleaned out the front and rear well cavities.
    Looks really good and further pisses me off that GM barely painted the cars structural parts. I mean, even the firewall is hardly painted
    um, wow. you're nuts.
    I'll take that as a compliment! I am somewhat of a "clean freak" and looking at all the rusty suspension parts just got to me. Probably end up on medication sooner or later...
    Don't EVER look under my car. And you live on a dirt road too!
    Park City, Ut
    midnight blue
    2000
    Thumbs up
    To this:
    i like this. ir eally need a cleaning like this in my car.
  1. spring cleaning
    By chuck4345 in forum Firebird / WS6
    Last Post: 03-25-2008, 05:40 AM
  2. early spring cleaning :)
    By Stealthperf.com in forum Parts For Sale / Trade
    Last Post: 03-04-2007, 07:48 AM
  3. Spring Cleaning!!!
    By camaro_five0 in forum Camaro / SS
    Last Post: 04-17-2006, 02:30 PM
