03-25-2009, 09:54 PM #1
Need Some Help on a Fuel Injector
So Penwell opened this weekend and i went to see some cars race. When I left the track my car started to misfire pretty bad. I stopped as soon as I could to check it out because my air fuel gauge went rich. I think that one of the fuel injectors may have got stuck open because one of the plugs was clean and soaked with fuel while all of the rest of the plugs were coal black. I thought it was a coil at first but i took one off my buddies car and it didn't fix the problem. Can anyone think of what else it might be? I appreciate any help, thanks.
03-26-2009, 01:55 PM #2
is the car running now? You can make a redneck stethoscope out of a long handled screwdriver by putting your ear to the handle and the tip on the injector. Listen to it fire and compare it to one next to it. I would also check that plug and make sure it's firing....like you said, could be ignition related too. Depending on the miles on your plugs/wires I'd probably start with the ignition. Sounds like you already have some ideas though so just post back and let us know what you find.
03-27-2009, 05:05 AM #3
Thanks for that Idea of the stethoscope, ill try that when I get home tonight. I know for sure that the electrical system is good, when I tried my buddy's coil on my car i pulled the wire off the plug and it was shooting the spark. I also rolled the wires to see if the problem followed, but no success. If its not the Injector, this is going to get wierd fast because another thing i tried was that I connected the fuel line to the fuel injector rails and turned the key to the car to activate the fuel pump. Everything pressured up and I was expecting for that one injector to leak fuel but it didn't. Doesn't make sense to me.
04-02-2009, 05:32 AM #4
So I got my injector back from testing and it was fine. I also did a compression test on that cylinder and what a surprise! It read about 15 PSI. I checked another cylinder and it read 150, so I think I found the problem of why it won't fire. Now the next step is to take the head off and see why I lost compression.
I just think that it is wierd how it happened. I was just cruising the HWY at 1600 RPM in 6th gear when it started to act a fool! I have blown motors on the throttle but just cruising?
I guess its time for a 408 Stroker boys and girls
04-04-2009, 01:08 PM #5
After further review, I found out that I have a broken Rocker. The intake valve is not opening on Cylinder #2. So I guess no more stoker motor. I just wanted to let you guys know what I found maybe someone else has the same problem.
04-04-2009, 01:54 PM #6
Fuel Injector Tick
By j nix in forum Internal EngineReplies: 8Last Post: 10-29-2010, 10:00 AM -
Question: Fuel injector cleaning
By 2002blackz28 in forum General HelpReplies: 18Last Post: 07-02-2009, 09:03 PM -
Fuel Injector Tuning
By richard head in forum External EngineReplies: 0Last Post: 10-27-2008, 09:38 PM -
fuel injector HELP!!!
By 2fast4u in forum General HelpReplies: 4Last Post: 07-13-2008, 06:56 PM -
By johnnyv in forum General HelpReplies: 4Last Post: 10-20-2005, 03:35 PM
