03-25-2009, 04:16 PM #1
Trick Flow to introduce new LT1 head
So, I decided to write trick Flow about the Gen X heads they make for the LT-1 and ask them if they had a cam suggestion or some kind of data for these heads on a naturally aspirated 350 LT1. I had learned that the Gen X head was truly made for stoked, with supercharged, and nitrous engines and not really intended for stock stroke normally aspirated engines. I got a reply from Gregg Changet a tech at trick flow that says the following:
"Actually we are coming out with a new 21 degree LT1 head that would be perfect for your application. They should be ready in about 3-4 weeks. I would keep your eyes peeled to our website for these heads. They are more intended for the naturally aspirated crowd and will keep your compression up."
Gregg Changet
Trick Flow Tech
E-mail: [email protected]
Ph# 330-630-1555 ext. 4694
Fax# 330-633-2504
Interesting, Thought I would pass that along
03-28-2009, 09:58 PM #2
Here is the press release for these heads.
Trick Flow GenX™ Street/Strip Cylinder Heads for Naturally Aspirated GM LT1 Engines
AKRON, Trick Flow Specialties introduces the best-flowing cast cylinder heads available for naturally aspirated LT1 engines: Trick Flow GenX™ Street/Strip Cylinder Heads. Out-of-the-box, these heads are easily capable of producing well in excess of 500 naturally aspirated horsepower.
Trick Flow GenX Street/Strip Cylinder Heads for GM LT1 feature 54cc combustion chambers to maintain the factory 10.25:1 compression ratio, but have CNC-profiled and bowl-blended combustion chambers to maximize performance. The heads have 21° valve angles—reduced from 23°—to increase piston-to-valve clearance and unshroud the chambers for better flow.
GenX Street/Strip Cylinder Heads for GM LT1 also feature 185cc intake and 67cc exhaust Fast As Cast™ runners that duplicate the port shape and profile of fully CNC-ported runners. The result is near CNC-ported power and performance for the same price as standard cast cylinder heads—and the best-flowing cast LT1 heads available.
The fully assembled heads come with stainless steel 2.020" intake/1.600" exhaust valves, GM LS-style 1.300" double valve springs, chromemoly steel retainers and locks, guideplates, and ARP 3/8" rocker studs. In addition, these heads retain the use of all stock sensors and fittings. Bare cylinder head castings are also available.
Based in Akron, Ohio, Trick Flow Specialties offers products that provide "Ultimate Bolt-On Performance." Trick Flow's product lines include cylinder heads, intake manifolds, camshafts, valvetrain components, and more.
03-28-2009, 11:51 PM #3
sweet, glad i waited.
03-31-2009, 02:24 PM #4
Hopefully the price will be nice. If it is I will be useing these on my Budget Build 500.
Trick flow head/cam performance kit
By Whamhammer in forum Internal EngineReplies: 32Last Post: 04-10-2012, 03:37 AM -
Trick Flow Head/Cam Package??
By splitfinger09 in forum Internal EngineReplies: 47Last Post: 10-25-2010, 08:30 PM -
Trick Flow Cylinder Head Insight - CHP Insider
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 08-21-2009, 11:00 PM -
trick flow head&cam package?
By mite53 in forum Internal EngineReplies: 24Last Post: 02-20-2008, 06:20 PM -
Trick Flow head and cam combo
By 1969mach1 in forum Internal EngineReplies: 36Last Post: 12-30-2007, 07:15 AM
