    Huntsville AL
    Bright Green Metallic
    1998 Z28
    1LE Front and Rear Sway Bars W/Stock springs/shocks?
    How will this perform? I have a 98 Z28. Do you need to do the shocks and springs at the same time (hope answer is no)? How harsh is the ride with the 1LE sway bars and stock springs/shocks? Finally, where can I buy them? I don't want the 35 mm etc. I'm worried the 1LE may be too harsh for my ageing back! But I really want better handling.
    Thanks,
    Jim
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    you do not have to do the shocks and springs at the same time. they won't make the overall ride any more harsh. the stiffer springs and shocks would make the ride more harsh. what you'll notice with larger sway bars, is less body roll going through corners. a quicker response to steering wheel input.
    Huntsville AL
    1998 Z28
    Do you have an recommendations on where to buy the parts? One reason I want to do this now is my end links have the bottom bushing very brittle and crumbly looking. I need to replace that on both sides so this is a good time to make this upgrade. Is there a whole 1LE package from a vendor? I may consider the whole deal if it's not too expensive.
    Thanks,
    Jim
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    www.stranoparts.com
    end-links are cheap... get an extra set when purchasing the swaybars... and the springs/shocks are totally independant of the swaybars, and can be done at any other time... so the answer is no, as you were hoping.
    Eugenio_SS
  1. Front and Rear Sway bars
    By JwMonE99 in forum Suspension and Handling
    Last Post: 10-09-2008, 12:32 PM
  2. MAf,AGX rear shocks, Strano sway bars,1LE sway bar
    By AFASTYZFR1 in forum Parts For Sale / Trade
    Last Post: 09-21-2008, 01:54 PM
  3. F/S Z06 Front and Rear Sway Bars
    By GOAT6SPD in forum Corvette
    Last Post: 01-25-2006, 05:03 AM
  4. 4 sale 1LE sway bars front and rear
    By in2protour in forum Western Members
    Last Post: 01-22-2006, 04:44 PM
  5. F/S...Z06 Front and Rear Sway Bars
    By GOAT6SPD in forum Vehicles For Sale / Trade
    Last Post: 01-14-2006, 11:52 PM
