Results 1 to 10 of 10
Thread: drag tire
    Feb 2008
    york pa
    96 ws6
    drag tire
    Anyone running a 15x10 on the back and if so what is a good tire that hooks at the track. Ill be pushing about 520 on the spray out of the gate. I'd like to keep the height at 27 inch because I have 355 gears
    🤔 11s. blackbirdbrain89's Avatar
    hagerstown, mercersburg
    black trans am
    2000
    well it seams u know every thing ur looking for but a brand... m/t it what i see 75% of the time if they weant good no one would use em
    Member GotN2O's Avatar
    NM
    Put on Mickey Thompson drag radial. They will hook every bit as good as a slick.
    Feb 2008
    york pa
    96 ws6
    That's what I was thinking, thanks
    black trans am
    2000
    520 hp on RD's u can do it but u better have the car set up or ur going to blow them off like street tires
    Boosted Fredneck Mark98SS's Avatar
    Frederick, MD
    9.62/140
    I run a 275-60R15 MT radial (28" height) with a 3.50 gear, works good, only time I see wheel spin is when they are wore out down to the cords. Nice thing about the radials is you run more air pressure so they handle much better
    black trans am
    2000
    Well as i posed mark ur car is set up.... if u take ur the power of ur car and put on to a stock set up DR's might not hold the power ....
    NM
    If the car is not set up suspension wise then it will not hook whether he runs a slick or drag radial.
    Senior Member BLKCLOUD's Avatar
    Knoxville, TN
    B2300 (Fluffy) Retired
    Plain-Jane Dodge Truck
    Nothing's better for hooking than a true slick. However, you might not need it, depending upon your setup and goals.
    Is the car an A4 or M6?
    What is your rpm limit?
    What is your best guess for finish line mph?
    Stock-style suspension or more race oriented (not talking just basic bolt-ons)?
    black trans am
    2000
    Quote Originally Posted by GotN2O View Post
    thats what i was trying to get at....
    Quote Originally Posted by BLKCLOUD View Post
    Stock-style suspension or more race oriented (not talking just basic bolt-ons)? .
    also note that ur going to want to know gear's and hope u know that with a 3 link u can run as good as a 4 link just have to know what ur doing... so race type set up is stock.... with zero adjust ablitly.... takes mark98ss hes got full set up springs shocks adjustable lcs tq arm and deag sway bay a long with the 500+ rwhp and he can use drs... but if he wanted to realy get his 60s down he could go with a bigger stall and softer tires and realy get outta the hole.... u can have 1000 hp ls1 cars with drs and still be fine hell i have seen a 1200 hp camaro run mid to low 9s on drs but he cam out of the hole like grandma going to the store
  1. Drag Wheel & Tire Setup
    By ls1camino in forum Parts For Sale / Trade
    Last Post: 06-08-2013, 04:14 PM
  2. Drag Tire Question?
    By camarostripes96 in forum Wheels and Tires
    Last Post: 03-24-2009, 08:33 PM
  3. Question: Tire Pressure for 275/50R15 MT Drag Radial Tire?
    By WS6ICK in forum Wheels and Tires
    Last Post: 12-01-2008, 01:51 PM
  4. Fitting a 11.5" tire (also, some drag tire ??'s)
    By Mr. Luos in forum Wheels and Tires
    Last Post: 10-07-2007, 07:31 AM
  5. NEED HELP!!! On which 315 Drag tire i should buy!!!
    By NeeD4SpeeD in forum Wheels and Tires
    Last Post: 10-15-2006, 10:11 PM
