Results 1 to 20 of 21
    Junior Member ASC420's Avatar
    May 2008
    kentucky
    02 Trans Am WS.6 (A4)
    Hand Held Programmer.....?
    I was checking into little hand help programmers and i ran across a hypertech hyperpac...i just wanted to know if anyone has had any experience or any good/bad things that people know about these things....because from what i read they sound like a pretty nice tuner.
    hanging around... LS1Jason's Avatar
    Mar 2009
    Henderson, Tx
    '99 -- Z/28 -- Pewter
    for a basic tune, i'd save half the money and do a mail-in. just my opinion.
    May 2008
    kentucky
    well what would be a good place to do that....about how long do they have it out?
    Junior Member 99TransAmWS6's Avatar
    Mar 2009
    Birmingham, Alabama
    1999 Trans Am WS6 Convert
    I want to do that too?
    Mar 2009
    Birmingham, Alabama
    texas speed can do it.
    Mar 2009
    Henderson, Tx
    http://www.lsxtune.com/services.htm
    or check out TSP.
    and i believe a couple of the members on here actually offer mail-in tunes. can't remember who at the moment though.
    Last edited by Y2KPewterSS; 03-19-2009 at 03:43 PM. Reason: Removed non sponsor link
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Quote Originally Posted by 99TransAmWS6 View Post
    They are not a sponsor and I would trust Frost over them anyday to do a mail order.
    Look up the member here named " Frost". Just go to the computer and tuning section of LS1.com and his name will be all over there, with a long thread about mail ordering tuning.
    Mar 2009
    Birmingham, Alabama
    I just dunno what to put down for idle speed and shift points and stuff
    Mar 2009
    Henderson, Tx
    they'll know whats best i'm sure for stock or simple bolt-on mods.
    Florida
    1999 TA WS.6
    Your pretty close to stock right? No cam or heads I assume. Put stock for idle speed. I dont see why you would want to raise the idle with just minor bolt on.
    Shift points, maybe send him a PM and tell him you want to firm them up alittle bit and take the delay out.
    May 2008
    kentucky
    what do you do unbolt your pcm and send it in the mail to one of those places?
    Mar 2009
    Henderson, Tx
    Quote Originally Posted by ASC420 View Post
    thats correct.
    Our car came with a Hyperpac and it is a nice unit -- I use it primarily for reading sensor data. We had problems with the secondary air system and it was good for reading and re-setting DTC's. I will be adjusting my fan temps this weekend as I just installed a cooler thermostat and may play with shift points. My understanding is that the Hyperpac is not the favored unit among the hand held tuner crowd...
    May 2008
    kentucky
    Thats what ive heard as well.. not many people on here like the hypertech units very much at all, but that hyperpac looks like a pretty cool hand held.
    May 2008
    kentucky
    I know this is way off topic but i just wanted to know if anyone have painted their calipers themselves, if it was hard?, how much it cost, if the color matched pretty good, and where to get a kit?
    Mar 2009
    Henderson, Tx
    i haven't myself, but I'm sure theres quite a few threads around that talk about it and possibly step by step. check the appearance section. good luck!
    I do not know how to reference another thread -- here is what I posted a few days ago in response to a similar question:
    I just did my brake calipers over the weekend: 1) Removed the caliper and used a coathanger to hang it from the wheelwell. 2) Unbolted and removed the caliper bracket and removed the brake disc. 3) Pulled the caliper pins from the bracket, plugged the holes and taped off the lip where the rubber boots seat. 4) Removed the rubber cap from the bleeder. 5) Used brake cleaner on all parts and then went over everything with a small brass brush. 6) More brake cleaner. 7) Taped off the brake hose and bleeder, used a garbage bag and newspaper to cover the suspension, axle and wheelwell. 8) Took a plastic cap from a can of spray paint and cut down the outside to about 3/8 of an inch (easiest way is to run tape around the cap for a straight line) and then slit the center part of the cap so it slides right into the piston and protects the boot also (had to cut a bit deeper for about 1/5 of the circumference for a tight fit). 9) Spray painted the caliper and bracket. 10) Also painted the center of the rotor and hub with POR using a foam brush. Worked great and I didn't have to bleed brakes when I was done.
    Member Lethal Z's Avatar
    Aug 2008
    St. Louis
    2022 SS Camaro
    With regards to the tuning contact steve aka Frost, here on the board. He does mail order tunes. His price is very reasonable, lots of guys here use him and he does very nice work. Leave the hyperjunk in the box. With regards to painting the rotors. I've been thinking about it, I've seen a few people do it. Problem is they look horrible when the paint starts to flake off.
    May 2008
    kentucky
    thats what i was wondering about....how long the paitn would actually last
    Aug 2008
    St. Louis
    2022 SS Camaro
    Don't get me wrong I like to save money too, but nothing looks worse then something that was half ass'ed done. I was looking at some calipers on an evo at the gas station, the calipers on it were a thing of beauty. Aint no home made spray paint job gonna compare to that.
  1. Question: which hand held programmer
    By SteveCZ28 in forum Computer & Tuning
    Last Post: 03-29-2010, 03:23 AM
  2. Question: Hand Held Programmer
    By Bama99z in forum Computer & Tuning
    Last Post: 07-08-2009, 05:35 PM
  3. Hand held tuners
    By Retired Cop in forum Computer & Tuning
    Last Post: 03-13-2009, 02:20 PM
  4. WTB Hand-held Programmer for 98 LS1
    By vannatte in forum Parts Wanted / Trade
    Last Post: 07-01-2008, 11:41 AM
  5. hand held programmer
    By maroca in forum Computer & Tuning
    Last Post: 10-26-2007, 02:47 PM
