Results 1 to 15 of 15
Thread: LS2 402ci STROKER HELP!!!!!!
03-18-2009, 08:54 AM #1
can any1 help me out wid this......lets say im putn 402ci stroker block n my o2 ls1 z28.....wat other things am i gnna have to change or modified wid my car for the 402 to work right...????? thanx.http://www.texas-speed.com/shop/item...d=684&catid=28
03-18-2009, 09:10 AM #2
- Feb 2006
- U. S And A Greatest country in all of world
Stock- 2002 Camaro
im not sure on the LS2 strokers, but i just bought a LQ9 408 stroker from TSP and the only thing i have to do is drill and tap a hole for the alt bracket. other than that it all carries over. i would imagine it would be the same for the LS2, but you may not need to drill/tap that hole. call and ask TSP they will be albe to tell you. have you already ordered it? you will also most likely want to get heads (unless you already have some). most everything else should cross over (oil pan, valley cover, intake, etc...) good luck
03-18-2009, 09:14 AM #3
- Feb 2006
Stock- 2002 Camaro
is there a reason you want the LS2 over the LQ9?
03-18-2009, 10:42 AM #4
03-18-2009, 12:21 PM #5
- Jan 2006
- Shepherd, Michigan
lightweight...save a hundred pounds off the front end.maybe to keep with the lsX line...besides that i cant think of too many reasons..i dont know the block flow characteristics between a lq9 and a ls2 ..but if i had to guess a ls2 will have better oiling and flow
03-18-2009, 02:22 PM #6
- Feb 2006
Stock- 2002 Camaro
ya i thought about the same thing, but i am thinking of going FI/N20 down the road, so the iron block appealed to me. i also have a tubular k-member and upper/lower a-arms which they say drops a little over 50lbs off the front. with the LQ9 weighing 60-70 more than it's LSX counterparts, i can stand to have 15-30 pounds more weight in the front. im not sure on any other differences either. do you think the oiling system is different?
03-18-2009, 02:26 PM #7
03-18-2009, 02:43 PM #8
03-18-2009, 03:10 PM #9
80-90 lbs of weight vs aluminum block
its enough that need to change out spring rates unless you want a lower'd look up front. look into using LT1 front springs when you add a Iron block motor up front if you want to keep the stock height
03-18-2009, 03:17 PM #10
03-18-2009, 03:32 PM #11
you should be fine but remember when you add weight to a given spring the spring rate now changes. so the ride might be stiffer up front. to some they dont notice this to others they can noticed the added weight. it does throw off handling some since its a higher weight
03-18-2009, 03:36 PM #12
03-18-2009, 03:51 PM #13
03-18-2009, 08:32 PM #14
03-18-2009, 08:33 PM #15
'02 35th SS w/ 402ci LS2
By LankyLS-1 in forum Vehicles For Sale / TradeReplies: 2Last Post: 06-12-2014, 06:35 PM -
MY 01 402ci SS camaro vs terminator vs gt500 with video
By william SS in forum Kill StoriesReplies: 109Last Post: 12-17-2010, 06:12 PM -
My APS 402ci twinturbo build..pics
By TNTramair in forum Forced InductionReplies: 168Last Post: 11-17-2008, 12:55 PM -
My Ws6: 996 Turbos vs. H22-35R vs. 402ci camaro vs
By My Ws6 in forum Kill StoriesReplies: 0Last Post: 04-22-2008, 10:24 AM
