Results 1 to 1 of 1
03-17-2009, 10:40 PM #1Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Dart Iron Eagle Cylinder Heads Install - Minimal A
Dart Iron Eagle Cylinder Heads Install - Minimal Assembly Required!
We give our Dart 372 Short-Block a pair of Dart 23-degree Iron Eagle Cylinder Heads and slap it on the dyno to see what kind of horsepower we can get out of it.There are a number of benefits associated with building an engine from scratch. Not only do you get the enjoyment of bolting the thing together yourself, but a certain amount of pride goes along with it as well. You can say with the upmost confidence, "I did it." However, time seems to be scarcer than before and things can quickly turn south if you aren't careful. Wrong measurements can quickly send your once simple small-block build spiraling out of control with one-off custom components that can't be returned. Yes, this can happen to any engine builder-even the seasoned pros. What's worse is that it could push your build onto the back burner for a while.
Photo Gallery: Dart Iron Eagle Cylinder Heads Install - Chevy High Performance Magazine
More...
L92 Cylinder Heads Install - It’s All In Your Heads
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 05-24-2011, 07:10 AM -
Dart Heads
By Brownboy2020 in forum Internal EngineReplies: 3Last Post: 08-20-2007, 04:53 PM -
cylinder heads dart vs. afr
By silverz28camaro in forum Internal EngineReplies: 3Last Post: 01-30-2007, 08:00 PM -
Dart Speed Flow Cylinder Heads?
By waldo31031 in forum Internal EngineReplies: 8Last Post: 03-01-2006, 06:46 PM
