Results 1 to 15 of 15
Thread: Nitrous install
03-11-2009, 05:16 PM #1Junior Member
- Oct 2007
- NY
Black- 97 firebird WS6
Nitrous install
Approximately how long does it take to install a complete nitrous kit including window switch and all the goodies (bottle warmer, purge, etc)?
03-11-2009, 05:31 PM #2
It took me a solid weekend, but at the same time, I was anal about wiring locations and trying to hide some of it on my last vehile. If you could care less about appearance - I've heard as little as 4 hours, but I call BS on that. Give yourself a solid day. It toom me a few hours just to mount the bottle bracket to my liking and run the line to the engine compartment.
03-12-2009, 04:11 AM #3Junior Member
- Mar 2008
- Warminster, PA
I usually tell customers to expect it to be a weekend job. I would recommend throughout the week to just lay stuff out and figure out where you'd like to mount things so come the weekend, you're installing instead of looking.
Nick
03-12-2009, 01:24 PM #4
moving to the n2o section
03-12-2009, 02:28 PM #5
4 hours with experience, soldered wires, heat shrink.
03-13-2009, 08:50 AM #6Member
- Urbandale, IA
Red- 2002 Trans Am WS6 (M6)
I spent most of a weekend on mine. My airbrushed bottle is mounted on the rear hump between the seats and the blow down was made by me to go out under the rear passenger seat. Arming, purge, & heater switches are on a panel I made for the ashtray. Purge is through the nostrils on my WS6 but had to avoid my BGRA set up that has the hood tight to the airbox. The wiring is hidden except where it goes to the actual WOT switch, etc. in the engine bay. I also installed custom covers (fuse boxes, PCM, and a couple of special made items for my intake/purge setup) during this same time. Depending on your setup and how many extra things you're doing at the same time, you could easily get it done in a day or less.
03-13-2009, 02:26 PM #7
It just depends on how good your skills are. . . . . . . . . . . For some wiring can take forever. BUT for those that aren't good at it it's MUCH better to take your time and do it correct versus quick and shitty.
I would plan on the vary least a solid day. If you don't have everything you need than more than likely a couple by the time you chase down parts.Don't be afraid of the bottle!!! Be afraid of your tune!!!
03-17-2009, 12:02 PM #8
Took a friend and I around a good 8 hours. Then the fun began...
Just take your time and make sure you do it right, dont cut any corners to save 5 minutes.
05-19-2009, 05:06 PM #9
A good 10 hours on my part. Thats including time to research a wiring diagram, test fit parts and decide on locations for everything. Give yourself the weekend and take it in 2 parts.
05-23-2009, 11:11 AM #10Member
- Jun 2008
- ohio
black- 1998 Camaro SS
im getting ready to install hsw 100 shot dry on the 98 ss. what did you guys use to make the bottle angle right when mounting it on the hump between the rear seats? I know they make something you can buy but i think it looks bad and wondered if theres something cheaper than $80 for that thing.
05-23-2009, 01:58 PM #11
I believe any bottle brakets will do... they should be stepped in height. You may consider mounting to a thin sheet of wood hidden under the carpet. I'd be afraid to accidently hit the fuel tank underneath just drilling into the metal.
If you dont like it in the hatch, you always have the option to mount it in the spare tire area pretty easily.
05-23-2009, 02:25 PM #12Member
- Jun 2008
- ohio
I was talking about mounting it on the hump between the rear seats. the hump like angles down so even with the brackets being stepped it isnt raised enough.
05-23-2009, 06:51 PM #13Junior Member
- Oct 2007
- NY
I had my kit installed and they put it in the "well" in the rear hatch. Fits n looks great!
05-24-2009, 07:58 AM #14Member
- Urbandale, IA
Not sure if there's anything cheaper unless you make something yourself. I used the mount from Nitrous Outlet (painted black) and the billet bracket from Harris Speed Works since I could get it in anodized black. Neither was cheap but was the look I wanted for my airbrushed bottle. If you've already searched here, try tech and you can find examples of what other people have done.
05-24-2009, 09:45 AM #15Awaiting Activation
- May 2009
- CT
Question: Should i install my LT's or just go with Nitrous.
By karpetcm in forum External EngineReplies: 5Last Post: 03-29-2010, 07:44 AM -
About to install first nitrous kit
By Whiteboycntdnce in forum NitrousReplies: 1Last Post: 06-03-2007, 08:12 PM -
Bayarea...Nitrous install? recommend me a shop or member to do the install? Price?
By 2klude in forum Western MembersReplies: 5Last Post: 04-11-2007, 09:30 PM -
HSW Nitrous Install
By Danger731 in forum Western MembersReplies: 96Last Post: 04-10-2007, 07:37 PM -
? on nitrous install
By jwcardy in forum NitrousReplies: 9Last Post: 12-06-2005, 07:16 PM
