    Junior Member dermot's Avatar
    Mar 2009
    Dubai
    1999 Firebird TA
    can't select reverse properly...
    Hi,
    1st of all, I'm a new Firebird T/A owner, in faraway Dubai (what!), I just bought a '99 6 speed with quite a few mods, including (I think) a B&M Ripper shifter.
    The damn thing quite often 'pops' out of reverse as you engage the clutch, and it is not so easy to select it either. All other gears are fine...clutch seems fine, no drag, can get 1st ok...
    -Can this be some adjustment or similar?
    Thanks,
    Dermot.
    PS: More dumb questions later I expect...
    Mar 2009
    Dubai
    1999 Firebird TA
    Helloooo.....
    ....listen for echo of own voice...
    -D
    Michigan
    Onyx Black
    2000 Berger SS #21
    I had a problem with popping out of reverse on my 2000 camaro w/ 6 speed. Turned out to be the shift fork pads on the reverse fork. The are plastic and if you accidently force it in to reverse when you are trying for 5th gear they may be damaged and cause reverse to pop out. There may be some other reasons but that is what happend to me. It is a relatively easy fix but the trans must come out to do so. The pads were only about $1.00 each. 2 are required.
    Pittsburgh
    2008 Hummer H3
    Synchronizer may be shot or worn. Just guessin' though.
    Michigan
    Onyx Black
    2000 Berger SS #21
    If it is the synchro you should be able to just flip it over and use the other side. Reverse only uses one side.
    Coral Springs, Fl
    Sunset Orange Metalic
    Can either be forks, syncs, or maybe something with the reverse lockout.
    Just my .02
    Mar 2009
    Dubai
    1999 Firebird TA
    Thank you guys, I had reluctantly come to the same conclusion about those plastic pads, I think it is those....
    Oh well, gearbox out someday soon...
    kr D.
  1. Help Me Select My Mods
    By Naaman in forum Camaro / SS
    Last Post: 05-20-2010, 06:06 AM
  2. EMPI select unit FS
    By EVL LS1 in forum General Classifieds
    Last Post: 05-25-2008, 11:44 AM
  3. FX3 Select Ride on a C4
    By Blue Admiral in forum Suspension and Handling
    Last Post: 12-10-2007, 08:37 AM
