    Michigan
    2000 Z28
    1st to 2nd shift
    could use some help? 1st to 2nd gear seams to slip or overrev, is the trans going or it something else. I am new to the ls1 trans any help would be appreciated, not working right now. Thanks Paul
    Pittsburgh
    2008 Hummer H3
    Smile
    Quote Originally Posted by MichiganZ28 View Post
    It's possible your trany is shot. However check the fluid if it's an auto ( in patk and warmed up to opperating temp). Also you may look into haveing it reprogramed at a shop. Shift points maybe in the wrong spots. Hope this helps. Good luck.
    Senior Member bills98ta's Avatar
    Feb 2007
    St Thomas, PA
    At WOT, I must leave mine in OD or Drive for it to shift, without hitting the rev limiter...
    old timer blue02Z's Avatar
    2002 Z28
    how well does it shift into 4th? the 2-4 band could be burnt
  1. Question: 1-2 shift
    By derekbuckner1 in forum Drivetrain
    Last Post: 04-24-2012, 06:14 AM
  2. Automatic Shift boot and new shift handle
    By stew215 in forum Appearance Section
    Last Post: 04-21-2011, 02:04 PM
  3. Looking for a shift kit
    By Tx98Formula in forum Automatic Transmission
    Last Post: 06-29-2010, 06:58 PM
  4. Vinci tuner shift firmness increase vs Shift kit ?
    By Formula in forum Automatic Transmission
    Last Post: 02-22-2009, 08:37 AM
  5. when should i shift????
    By dude2race in forum Computer & Tuning
    Last Post: 03-15-2006, 05:24 PM
