Thread: Rear-end info
03-09-2009, 07:28 PM #1
Rear-end info
Hey everyone
Just found out the funny sound coming from my 2001 Ws6 was the rear-end and it looks like it is blown. This sucks because when I get the car 2 years ago I had this funny sound and was told it was the rotors. I parked it for almost a year and just took it out and the sound is worst. So I need rebuild my rear so do I have a 10 bolt or 12 bolt in the rear? Also what type of gear should I go with since I am having the work done? I heard the 3.73 would really work my motor when I go over 70 or should I go with a 3.55. help
03-09-2009, 08:15 PM #2
I know what you mean I though it was the larger tires making noise but when I hit 135 the rear gave out and the noise got 10 times worse. Chewed a few gears too. I had mine rebuilt but it's starting to make noise again. I do beat on my car a bit though. t's a toy and for me that's all it's for. If you plan on adding more power I'd get a better axle. You should have a 10bolt unless it was changed. I've heard a 3.73 is ok in an auto. I was planning on using it but I am changing my car to a 6spd and going with a 4.10. Oh and the 3.42 is a little easier on the mpg but still better than stock.
1998 Trans Am 85k miles.
02 Trailblazer -Sold
09 Ram 1500 CC - Sold
09 Cobalt SS/TC - Sold
03-09-2009, 08:22 PM #3
Hey RyanJM thanks for the help, after your rebuild your end was back to par how long it take you to blow it again? I am looking at spend over a G for the rebuild and the gear of my choice, I would hate to have the work done just to have to redo it in 2 or 3 years.
03-09-2009, 09:52 PM #4
i had a whine coming from my rear end and had changed the bearings and gears to 3.73 cost 750$ and then i broke it during a race so now im just waiting for a new rear because to rebuild it cost aroudn 1500 and a new 12bolt is 3k with install
03-10-2009, 11:05 AM #5
- Apr 2008
- Winnebago Il.
black- 2000 Trans Am
what kind of noise did your guys rear end make? because mine has almost a grinding sound comming from it or like something rubbing?
03-18-2009, 12:21 PM #6
Hey guys just got back my WS6 today the rear was shot bearings went bad so I had some stuff replaced cost me 1023.26 plus I had new rear brakes put on and rear rotors shaved. it will cost me $410 (with gear cost) to change to a 3.73 is it worth it?
03-18-2009, 12:56 PM #7
- Jun 2007
- Lathrop, Missouri
NOpe for $1k more you could have bought a brand new 9" and never had to worry about it again. Word of thumb when it it comes to a 10 bolt. replace DO NOT re build.
03-18-2009, 04:20 PM #8
- Nov 2005
- pomfret, ct
- 2000 ss
If you can do the work yourself and you want a gear change you can stick with the 10 bolt. Like Jay said, for a grand, go 9".
Rear alignment is off after Koni/!= rear isolator lowering, car pulls to right, specs
By anestech* in forum Suspension and HandlingReplies: 13Last Post: 07-08-2007, 09:42 AM -
Rear alignment issues after removing rear spring isolaters, adj trac bar fix it?
By anestech* in forum Suspension and HandlingReplies: 1Last Post: 06-19-2007, 07:06 PM -
Anyone have any info? (Computer info)
By blackSS01 in forum Almost Anything GoesReplies: 3Last Post: 02-01-2007, 01:44 PM -
Auburn rear info needed
By 2000 SS #1305 in forum DrivetrainReplies: 4Last Post: 04-01-2006, 09:11 PM
