Results 1 to 13 of 13
Thread: pulstar plugs
    Junior Member EasyEp's Avatar
    Mar 2009
    Salt Lake City
    RED
    2006 gto
    pulstar plugs
    anyone dealt with them? are they safe for a gto? or should i be the guineapig?
    Senior Member qwkgto's Avatar
    OHIO"S only 9 second GTO
    Phantom Black Metalic
    2005 GTO
    I would stick with the normal,what exactly are they what type?
    Mar 2009
    Salt Lake City
    RED
    2006 gto
    they are a different type of plug, check out pulstar.com, they improve mph and hp. but they cost 25 bucks a plug. the site says they are safe but thats the site saying it.
    2005 GTO
    rocket sceince eh?lol well i think i will do alot more research on this plug before I oput it into my FI car. NA, ok any time you add more hotter spark its going t effect something.
    the lsx ignition system is a pretty good system right out of the box. I have trouble spending too much money on the ignition side of. The lsx coils fire hot as hell through some really short plug wires.
    Retired Outlaw Sum Bitch
    Bullshit more HP/MPG....guys if you have proper timing and compression then there is no difference between lighting it off with a spark or a blowtorch....now I have blown out my spark at high RPM's and had to go with the MSD coils to get the multi spark....
    Mar 2009
    Salt Lake City
    RED
    2006 gto
    so what are some good ignition systems to replace to stock?
    Member PatrizioD's Avatar
    The Anus of America; RI
    Nero
    2006 gto
    Any write up on this? I pulled off the engine covers the other day to look at the heads/coil packs and was wondering how hard they are to change out, since the MSD's caught my eye in my latest car magazine.
    2005 GTO
    The coils in our cars are pretty stout,im still running them ,have seen 18 psi,soon will see if they can hold the flame for 22 maybe more PSI.when I start having probems ill go to the MSDs not spending all that $ till I do,all I run is the MSD8.8 wire then again the wires are very short on these car the spark dont have far to go,always a good idea to replace any wires on a yearly basis,heat kills them more then anything.
    I have a brand new MSD LS1 coil still in the package I'll give you...then you can only pay for 7 and get 8. Of course you'll be my bitch for the rest of your life for one MSD coil but hey...what the heck huh?
    Quote Originally Posted by PatrizioD View Post
    VERY EASY. Just look at em.....you'll see real quick how to remove and reinstall....just don't break the lil plastic wire lock things like some big ass fat finger Texan shoving them lil bitty boogers back on......cuz if you break em you have to go look at trucks at the GMC/Pontiac dealership and when the salesman goes away for a minute steal the new ones off the truck and leave....
    2 badass birds
    OK
    RED/black
    97ws6/05 GTO
    OK so everyone knows for the millionth time. Electricity follows the path of least resistance. it will fire to the closest point if they are all 100% down to the millionth micro the same it will divide its power and you will have 2 weaker sparks instead of 1 hot spark. If it improved mileage that much OEM would use them for cafe reasons alone.
    here you all can learn something today .
    http://library.thinkquest.org/10796/ch13/ch13.htm#s1
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    I'll stick with my NGK Iridiums. Just swap and done.
  1. Enerpulse Pulstar Spark Plugs - Supersize Your Spark
    Last Post: 03-15-2013, 09:00 PM
  2. Pulstar Spark Plugs
    By lonewolf37 in forum General Help
    Last Post: 05-13-2008, 08:24 PM
  3. Pulstar Plugs
    By RandomOmen in forum External Engine
    Last Post: 11-27-2007, 10:16 PM
  4. Pulstar Plug
    By agentk006 in forum General Help
    Last Post: 08-21-2007, 05:19 PM
  5. Pulstar Plugs
    By RamAIR23 in forum External Engine
    Last Post: 06-14-2007, 04:35 PM
