Results 1 to 15 of 15
    At 3500 RPM's....
    What should the O2 voltage readings be if stoich?
    I would go higher...but the motor is brand new. And I would like to know what they are reading....
    Lowered, HID's, tinted.
    Senior Member ninobrn99's Avatar
    Aug 2003
    Honolulu HI
    all bore 370 Trans Am
    if you havent entered PE, then it should be stoich from what i gather. its only when your in PE or OL that you will see a difference in A/F. someone correct me if im wrong.
    I have voltage readings...probably not the most accurate...but should at least give me an idea how rich it is.
    At least that is how I took it.
    Maybe I am wrong.
    Token V6 Guy
    Trenton/NJ/US
    2000 Grand Prix GTP
    your stock o2's will/should switch back and forth anywhere between 0-1000mv at idle & part throttle.
    Quote Originally Posted by foff667
    I know.
    What about WOT at 3500-5500 RPM's??
    Token V6 Guy
    Trenton/NJ/US
    2000 Grand Prix GTP
    750-1000mv is normal.
    Alright then...those look good.
    Must be something else.
    Actually...thinking about it...
    Don't I want my O2's right around .920mV at WOT??
    Token V6 Guy
    Trenton/NJ/US
    2000 Grand Prix GTP
    stock o2's are completely innaccurate at any a/f ratio other then 14.7:1 so at .920 one car might be running at 13.0:1 and in another it might be 11.5:1...and those numbers could change from run to run & day to day. So the answer is no...using stock o2's give you no accurate info.
    Okay...but at the very least...they shouldn't being varying in voltage at WOT should they?
    We'll be back... GatorSS's Avatar
    THE SWAMP
    Light Pewter Metallic
    2000 Camaro SS M6
    Stock O2s are crap for info. Learned that the hard way.
    Token V6 Guy
    Trenton/NJ/US
    2000 Grand Prix GTP
    Quote Originally Posted by Mr. Luos
    they will/should move only slightly ie 850-900mv or 900-950, etc. But generally no they shouldnt fluxuate...not in fbodies at least...lsx trucks are a whole different story.
    Screw it....these stockers have been through hell.
    2002 C5 rears are ordered.
    Tech Junkie hammertime's Avatar
    Belleville, IL
    Pewter Metallic
    Ideally, you should use a wideband O2 sensor for tuning purposes. It can read the A/F ratio much more accurately than any stock type sensor.
    Cyles in a small range for the stock sensor is normal, but the farther away from stoich you get, the less accurate the sensor is.
    Hammer - hammertime.us
    2001 Light Pewter Metallic Camaro SS, 6 speed
    K&N, SLP Lid, SLP y-pipe, GMMG cat-back, Lou's Short Stick - more to come!
    I want to put a wideband on it eventually...just can't afford it right now. Maybe depending on tax refund.
    I was looking at my log file compared to a couple others and my O2's are acting much different. They seem to be 'lazy' and bounce around too much for my liking at WOT.
    I get the Delco C5 rears tomorrow.
  1. Tci 3500
    By ledesma54 in forum Automatic Transmission
    Last Post: 06-30-2008, 07:40 PM
  2. Is a 98 Z28 with 90k worth 3500.00?
    By johnshuler08 in forum General Help
    Last Post: 06-12-2008, 09:54 AM
  3. FS: TCI 3500 stall
    By haighter in forum Parts For Sale / Trade
    Last Post: 03-07-2008, 08:40 PM
  4. Yank SY 3500 1.61 STR
    By Wheeler99WS6 in forum Parts For Sale / Trade
    Last Post: 05-26-2007, 09:50 AM
  5. HELP.-cant rev past 3500 rpm
    By unnatural aspirations in forum General Help
    Last Post: 09-21-2006, 06:11 PM
