Results 1 to 1 of 1
Thread: 1969 Chevy Camaro - Razor
03-04-2009, 03:10 AM #1Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Quick Inspection</br> '69 Chevy Camaro</br>Erv Woller/Ringbrothers</br>Spring Green, WI</br></br>Powertrain</br>Engine: The all-aluminum 454 crate motor was built from GM's ZL1 block that still utilizes the original tooling used in 1969. The ZL1 uses GMPP's Ram Jet fuel injection originally introduced on the Ram Jet 502. A forged crankshaft, rods, 10.2:1 pistons, and 0.640/0.598-lift solid roller cam create the noise. Plumbing is done with Aeroquip hoses.</br>Power: As tuned by GM, the ZL1 makes 510 hp at 5,750 and 493 lb-ft at 4,250.</br>Transmission: To counteract the steep rear gears, the trans is a Tremec Viper-spec six-speed.</br>Rearend: The rearend is a custom-built Currie 9-inch with 4.56 gears on an Eaton Truetrac differential.
Photo Gallery: 1969 Chevy Camaro - Hot Rod Magazine
More...
1969 Chevy Camaro - The Fun Factor
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 05-05-2011, 03:10 AM -
1969 Chevy Camaro SS - Joy Ride
By Ed Blown Vert in forum Camaro / SSReplies: 1Last Post: 08-04-2009, 03:17 PM -
1969 Chevy Camaro - Lazer Z
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 05-26-2009, 10:50 PM -
1969 Chevy Camaro - The Four Corners
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 12-19-2007, 10:50 PM -
1969 Chevy Camaro - Toughing It Out
By Ed Blown Vert in forum Camaro / SSReplies: 1Last Post: 03-09-2007, 04:11 PM
