Results 1 to 10 of 10
    Member Siciliano15's Avatar
    NY/CT
    1998 Trans Am WS-6
    which valve springs are better
    i need to get a new set of valvesprings. i have a '98 trans am with 53,000 miles on it. i dont plan to change the cam so i am going to get some harland sharp 1.8 roller rockers. i know i need to change my springs so i was looking at these two options:
    http://www.byunspeed.com/product_inf...oducts_id=6291
    or
    http://www.ws6project.com/user_stor/...oducts_id=2523
    i can see theres a big price difference but is one spring really any better than the other?
    mercersburg pa
    hugger orange
    2004
    I did and would go with the Comp 918 springs since you will be under .600" lift
    NY/CT
    1998 Trans Am WS-6
    Quote Originally Posted by mark21742 View Post
    do u think its worth the extra $109 over the ls6 springs though? just trying to keep a lower budget but still have the reliability for when i go to the 1.8 rocker.
    mercersburg pa
    hugger orange
    2004
    Quote Originally Posted by Siciliano15 View Post
    with the added lift the 1.8 rockers will give you i think the ls6 springs might be alittle too small....personally I wouldn't chance it
    NY/CT
    1998 Trans Am WS-6
    oh ok. what about those granatelli springs.... they say they increase the hp by 15-20 for applications under 560 lift but im not sure if thats just a marketing gimmick or if its true...
    mercersburg pa
    hugger orange
    2004
    a valve spring shouldn't be an hp adder.....i will tell you I've been sucked in to "buy this it will add 10hp" before and those parts are not on my car anymore
    NY/CT
    1998 Trans Am WS-6
    thanks a bunch for ur help
    mercersburg pa
    hugger orange
    2004
    hey man, not a problem. good luck with the build!
    owings mills,md
    2002 camaro ss m6
    Go with the ls-6 springs with your stock cam as they are good for 570 inches of lift which is roughly a .030 increase in valve lift .youre pre 2000 ls1 stock cam has .500 inch valve lift which would put you at .530 lift thats well below the .570 the springs can handle.
    NY/CT
    1998 Trans Am WS-6
    Quote Originally Posted by JEFFLS1Z28 View Post
    sounds like a good idea especially that i just found the set of LS6 springs for only $52 from Lingenfelter.
  1. Valve cover gaskets, Valve Springs, Timing Gasket
    By Dewman in forum Parts For Sale / Trade
    Last Post: 01-22-2010, 08:14 PM
  2. valve springs,HAL struts and springs,grannatelli lid
    By nosty1 in forum Parts For Sale / Trade
    Last Post: 07-25-2007, 05:23 PM
  3. struts/springs,lid,ls6 valve springs,F-body fuel pump hotwire kit
    Last Post: 06-30-2007, 03:33 AM
  4. valve springs?
    By raptor2 in forum Internal Engine
    Last Post: 05-19-2007, 11:46 AM
