Thread: Error Code P0125
03-03-2009, 01:53 PM #1
- Aug 2007
- Texas
Error Code P0125
I went to the post office today, and as i got a mile or two down the rode i got a check engine light
I ran it, P0125, insufficient coolant temperature for closed loop fuel control.
What does that mean?
03-03-2009, 02:24 PM #2
- Nov 2006
- Indianapolis
Usually means your thermostat is bad, opening too soon. Replace it, make sure the coolant is full, clear the code and you should be golden. On the 3.8 it is easy to get to, right on top front, correct? Under the top radiator hose.
03-03-2009, 02:30 PM #3
- Aug 2007
- Texas
I have no idea where its at. sounds like a good reason to me. my car was over heating about 3 weeks ago, got a little hot a few days ago too
03-03-2009, 08:15 PM #4
- Aug 2007
- Texas
Help me out guys
03-04-2009, 03:04 AM #5
- Nov 2006
- Indianapolis
How's your coolant level? If it is too low it can cause both the overheating issue and the P0125. If your coolant is low, where did it go?
First thing I would check is the water pump. Look on the bottom side of it, there is a weep hole, that's usually where the leak shows. The bottom part of it, just behind the pulley. Might need a small mirror to help see it.
P0430 error code
By 98TransAmWs-6 in forum External EngineReplies: 2Last Post: 10-15-2010, 10:21 AM -
Help: 02 z28 M6 error code help
By kool-aide in forum General HelpReplies: 27Last Post: 10-29-2009, 01:53 PM -
DIC error code P1416
By DaveC5 in forum External EngineReplies: 1Last Post: 05-15-2008, 03:54 PM -
P0430 GM Error code Help...
By in4sit in forum General HelpReplies: 0Last Post: 09-01-2007, 05:29 AM -
Help with error code
By THOMAS81Z in forum Internal EngineReplies: 2Last Post: 08-09-2005, 07:30 PM
