Thread: Vibration & Banging need advice
01-21-2006, 10:53 AM #1Junior Member
- New Jersey
Black- 1998 Formula WS.6
I just got my car back almost 2 weeks ago and I have been driving real easy until the new parts are broke in. Anyway I decide to give her a little more gas on the 1st to 2nd shift and I let out the clutch and then all the sudden I hear and banging from underneath the console area.
I take her back to the body shop and they check everything they pulled out the trans X member a litt was bent. They took off just to check if it were the problem some metal sheild under the exhaust. Nothing worked.
So they start check up by the area where the pedals are since I now have a little area in front of the dead petal where the floor pan goes in and out, like a soda can. They grap ahold of the exhaust/Y-Pipe and move it around and notice the engine moving I need new Motor Mounts and Transmission Mounts.
I am just curious if anyone else had this problem? I just had her in the body shop a few weeks ago getting a new Cross Member put on you would think they could have noticed any bad mounts since I was told that they were good?
I have to order the new mounts from Thunder on monday going to get the Prothane ones since I really like their bushings and endlinks. I am going to have the shop install the mounts, I would just like to know how many hours should I epects for them to change my Motor and Trans mounts? I think it should be pro-bono since I just had them take the whole damn thing apart and could have saved whatever the labor cost will be.
Thanks for any help
Eddie
98 Ws6
01-21-2006, 07:35 PM #2
Banging from the y-pipe is a common problem from aftermarket Y's....mine bangs also so I ordered the bump stop from thunder. Do you have the stock y-pipe on there?
01-22-2006, 06:21 PM #3Junior Member
- New Jersey
I had an aftermarket SLP Y-Pipe put on. What is the "Bump Stop" you referred to at thunder? I have to order a new set of prothane motor and trans mounts should get the bump stop also. Did the bump stop cure you banging Y-Pipe problem?
Originally Posted by SeVeReDiStOrTiOn
How long should it take for them to install new motor & Trans mounts?
How long for th eBump Stop?
Thank you
Eddie
01-22-2006, 11:49 PM #4
http://thunderracing.com/catalog/?ac...&vid=3&pcid=54 It's on that page about 3/4 the way down and it's made by mufflex...I haven't installed it yet but I hear it works.
y pipe banging
By sezo in forum Camaro / SSReplies: 34Last Post: 06-11-2015, 02:23 PM -
y pipe banging...
By bolden3 in forum External EngineReplies: 7Last Post: 09-20-2007, 10:30 AM -
BANGING TRANNY in 2nd,3rd
By LETHALxLS1 in forum Automatic TransmissionReplies: 2Last Post: 07-16-2007, 03:32 AM -
Need some advice on vibration.
By Jasin in forum Camaro / SSReplies: 6Last Post: 03-25-2007, 07:36 PM -
banging off rev limitter
By Zboner in forum General HelpReplies: 16Last Post: 11-24-2005, 10:45 PM
