Thread: 10 bolt fear!!
02-27-2009, 04:55 PM #1Member
- Jun 2008
- ohio
black- 1998 Camaro SS
10 bolt fear!!
I just watched several videos on youtube of 10 bolts breakin. im now very scared. i didnt really know how bad they were till after i spend all the money i have on heads/cam/headers/nitrous. ill be sitting around 480-500hp on spray with stock rear end. is there anything i can do to prolong is life until i have enough cash to get a 12 bolt other than no burnouts or launches? Will one of those rear end covers really strengthen it?
02-27-2009, 06:45 PM #2Senior Member
- Jun 2007
- corona ca
white, white and pewter- Rip99SSA4,74Z28M4,02SSM6
they are really not that bad, ive been thru only 1 in all my years, although i dont have that much power, its just really in the maintenance and how much you beat on it,
i have a buddy making 520hp 580tq on a stock clutch, stock tranny and stock rear with mickey's without any problems.
just save up, you will be fine
02-27-2009, 07:13 PM #3Just me
- Nov 2006
- Broken Arrow, OK
Avoid all launches and burnouts like you said. Some are luckier than others, but there is nothing you can do that will strengthen that 10 bolt to hold up to the power you put through it. Just upgrade your rearend ASAP.
02-27-2009, 07:36 PM #4
Why no burnouts? The launches I see being an issue with all the additional stress and load....but with burnouts/kicking it sidways, I don't see nearly as much stress as lauching it at 3000 rpm with slicks.
02-27-2009, 09:53 PM #5Senior Member
- Jun 2007
- corona ca
you doubt our advice? preston and I have been thru a couple F body's in our time.
i doubt you could put any noteable stress on your rear without a big tire, my assumption is you have a drag radial at best there for your rear sees much more abuse and stress., were just saying be easy on it, and it will last till you can afford a 12 bolt or what have you.
02-28-2009, 02:50 PM #6Member
- Jun 2008
- ohio
i was looking at some 9" rear ends on texas speed and was wondering what is full spool and detroit locker. whats the difference? also was wondering what the best gears for my 98 ss m6 daily driver would be.
02-28-2009, 03:21 PM #7Just me
- Nov 2006
- Broken Arrow, OK
4:10s for the gears.
02-28-2009, 03:37 PM #8Junior Member
- Oct 2005
- On the internet
12 bolts
Having personally destroyed 3 10 bolts on the shop car with (soft launches), I can tell you that the 10 bolt is not going to hold up to drag launches with sticky tires for very long.
The automatic equipped cars usually help the 10 bolt to live longer since it takes some of the shock out of the drivetrain. The 6 speed cars are way more likely to shred the rear end on hard launches especially if you go to a 4.10 gear where you have more torque multiplication and physically smaller teeth on the gears.
Some people put on a rear end girdle but that will only marginally help.
Since a blown up 10 bolt will probably cost you 600-1000.00 each time, blow up two and you paid for a 12 bolt. You can also do the 9" ford which is a bit stronger than the 12 bolt.
We sell the Moser rear ends and they are very dependable and you can retain your ABS and traction control as well.Fast Toys Performance Parts
Low pricing & honest customer service since 1998!
Email:[email protected]
Web: www.fasttoys.net
02-28-2009, 03:59 PM #9
03-02-2009, 08:45 AM #10Junior Member
- Oct 2005
- On the internet
03-02-2009, 08:52 AM #11King 0f n00bz
- Jan 2006
- Shepherd, Michigan
the burn out itself isnt going to stress...but its when the tires catch(aka right after your burnout/kicking sideways..when the car jerks back thats where the stress is...also doughnuts are a killer too ...i am now 21 years old..have had my car coming up on two years,,and its seen alot of track passes..but i make sure and not do excessive burnouts on the street/doughnuts..ive done two doughnuts total with my car..both on the first day i had it...take care of the rear and it will take car of you .......to a point
03-02-2009, 06:16 PM #12
It's 2 am, The fear is gone
By SMWS6TA in forum Almost Anything GoesReplies: 9Last Post: 09-23-2010, 09:26 AM -
Who here has a fear of flying?????
By Mike97dakota in forum Almost Anything GoesReplies: 60Last Post: 09-30-2009, 02:30 PM -
Question: Fear the bottle or fear your tune?
By b.lee in forum NitrousReplies: 21Last Post: 04-17-2008, 02:32 AM -
Fear The Gay Chicken!
By FantaZGuy28 in forum Almost Anything GoesReplies: 26Last Post: 10-06-2007, 04:45 AM -
Fear the Gay Chicken!
By AKIRA in forum Almost Anything GoesReplies: 12Last Post: 08-10-2007, 04:54 PM
