    Boca Raton, FL
    2002 Camaro Z28
    2002 Camaro Z28 Noise issue
    i'm having a tough time trying to figure out what this noise is hopefully someone has some explaination what it is. it's definatley coming from the front drivers side wheel, wheel well. it only happens at low speeds ans it sounds like two pieces of metal hitting each other. the other thing is that it's not a consistant sound
    Feb 2006
    2002 WS6
    first thing to do, would be to have a peak and look for any thing that maybey caught in the rim and hitting something. Next step it jack that side up and remove the rim, getting a good look at things and giving the hub a spin, check the tire to for anything that may be stuck in the tread.
    is it a slight squeal? could it be the sensors on the pads rubbing the rotors? Many miles on those pads?
    Member slpdablueZ28's Avatar
    Sep 2008
    brooklyn
    blue
    2002 Camaro Z28
    if its a squeeky whistling noise then u might need to tighten ur lug nuts on ur wheels they might be loose thats the problem i had one time
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    Maybe an exhaust heat shield
    Boca Raton, FL
    2002 Camaro Z28
    thank guys its definatly not a whistling sound. i did check to see if anything was hitting and didnt see anything really noticable. in fact i have a video were you can hear it, ill try to post a link.
  1. Help: Idle issue 2002 TA
    By TA76 in forum General Help
    Last Post: 03-30-2013, 03:41 PM
  2. Temperature Issue 2002 Trans Am WS6
    By Zedtwentyeight in forum Firebird / WS6
    Last Post: 11-07-2011, 06:41 PM
  3. issue with grinding noise from transmission
    By bezerker03 in forum Manual Transmission
    Last Post: 12-01-2010, 06:28 PM
  4. Help: Acceleration issue and unrelated/related noise.
    By Speed Bump in forum General Help
    Last Post: 06-17-2009, 11:27 PM
  5. 2002 A4 z28 issue
    By IT_SS in forum Drivetrain
    Last Post: 12-26-2007, 08:55 AM
