Results 1 to 10 of 10
    NH
    2016 Silverado Z71
    1999 Camaro SS #1437
    Cool 3D Scanning Technology
    I could come up with a million ideas for this thing
    http://widgets.nbc.com/o/47f1317f105...a4377d3bfd6c81
    Greene, Iowa
    99 Chevrolet Camaro Z-28
    yeah this thing is neater than hell...i could think of stuff to do with it too. haha
    That's so amazing it's scary!
    Member ezwip's Avatar
    May 2008
    purgatory
    02 Z28 M6
    How much do you think it will cost to scan Alizee Jacotey?
    Crystal Lake IL
    2001 Camaro Z28 M6
    LOL thats nothing new...
    My company sells those 3D printers, called Dimension by Stratasys.
    I print on these all the times for conceptual parts, that I design, from throttle bodies, cars, cell phone to guitars. etc.
    The technology is FDM (fused deposition modeling) it pretty much works like a hot glue gun. The tips inside of the printer head, heat up, melt down the plastic and prints the plastic layer by layer on top of each layer. The plastic used in the model shown is ABS plastic. Same plastic used on keyboards, tv remotes etc.
    The benefit to these machines is rapidprototyping for form, fit and function, while being able to print moving parts.
    if anyone has questions feel free to ask.
    you can see more on my companies website, including the same vid you posted
    http://www.funtech.com/Products/Dimension-Printer
    Btw the smaller printing machines cost $15,000, the one in the vid goes up to $40,000, and there are higher ends, that $250,000
    how the hell does the scanner know when there is a non unified surface that touches? Such as, the gears rolling over other gears? I mean, they are touching-so why doesn't the laser just see those as one piece?
    my thought exactly...that whole steam engine replica built as one piece sitting inside that machine, built up of layers upon layers of plastic, voids between moving parts..The only thing i can figure is that it 'builds' the layers just like a CAT scanning machine 'takes them apart', so to speak.
    Crystal Lake IL
    2001 Camaro Z28 M6
    the next engine 3D scanner is a decent system at most. What they didnt show in the vid, is the front end 3D design you have to do to touch up the scan.
    The 3D scanner works, by scan point cloud or mesh data of the 3D object and then takes a digital picture of the objects to display the object as shown. Now the user has to align all of the point cloud/mesh data and convert it into a surface then a solid, using programs such as solidworks, solidthinking, or rapid works.
    Once that is done, an .STL file is created and sent to the 3D printer. The 3D printer uses a print driver that allows you to set up and layout the part as you see fit. This driver also recognizes spacing in multi-body parts. This spacing is printed with a water soluable supporrt material instead of the ABS plastic that the part is printed with. Dissolve the support and the part interacts
    We have printed working shocks, adjustable wreches and pinion gear setup. All of the parts move as they should.
    cooooooool. I thought about that after posting it. That the user had to define stuff in the 3d program. Pretty freakin rad, man!
    Junior Member cowboy_TA's Avatar
    Feb 2008
    Wyoming
    2000 Trans Am
    wow thats pretty sweet i want one lol
  1. technology a cool thing...
    Last Post: 12-30-2012, 06:44 PM
  2. cool fighter jet technology
    By ibanez7 in forum Almost Anything Goes
    Last Post: 05-19-2011, 09:26 AM
  3. Anyone in South NJ/Philly area w/scanning software?
    By MagicMan in forum Eastern Members
    Last Post: 10-21-2006, 04:59 PM
  4. Scanning software - don't want to get ripped off
    By Billdog350 in forum Computer & Tuning
    Last Post: 06-01-2006, 10:31 AM
  5. Cool New Shift Knob Technology from TWM
    By TWM Performance in forum Drivetrain
    Last Post: 09-12-2005, 12:56 PM
