    Senior Member qwkgto's Avatar
    OHIO"S only 9 second GTO
    Phantom Black Metalic
    2005 GTO
    gto twin turbo kit
    This is the most complete kit you can buy everything is bolt on,no cutting up the car,fits 05-06 GTO will work on 04 also exits from turbos will need changed on exhaust tips as the 04 has single side exhaust exits.
    The kit include two new turbos,one was leaking when I took this off my record holder GTO.some stats of my car stock bottom end ls2,stock ls2 cam this car has stock suspension,with the exception of drag bags and frame ties.I also have a one peice drive shaft,stock rear end gears posi axles etc. car has ran best of 10.6 and best mph 134 with 13 psi.
    THE kit includes all fuel related parts including fuel rails,injectors,lines Nastys twin intake pumps and all hook ups,all the exhaust from stainless works coated headers to exhaust tips,I can even provide that tune,the intercooler and all the piping,this whole kit bolts on to the car,via Vband clamps.
    $6000 shipped..
    pm me for details,I will offer tech support to buyer,the exhaust is all stainless,intercooler is all aluminum,Tail waste gates,and a tail 50mm blow off valve is the one you see in the picture above ,in the bend before it goes to the throttle body before entering the throttle.I have videos and time slips many pictures I can also provide.
    2005 GTO
    GTO1_OHIO
    Ohios fastest 04-06 NA
    2004 GTO
    Phantom Black Metallic
    You can't argue with success. There isn't any twin turbo other then RCs running 10.6 or better on a stock bottom, with a stock cam and with the 4L65E transmission. The guarantee to this system is to have Roger install and tune it.
    ...and actually according to this list on the other site. RC IS the fastest LS2 twin turbo in the country! His screen name there is rcsfastgto ... if you look bottom row, column three, that's the twin turbos. He's 4th overall on that list. three LS1s are ahead of him.
    http://www.ls1gto.com/forums/showpos...72&postcount=6
    I'll repeat ...fastest LS2 turbo in the country ...that's not too bad for a do DIY kit!
    The Angry Jew DarkFormula's Avatar
    Reynoldsburg, Ohio
    1998 BGC Formula A4
    1998 NBM Formula M6
    This is one badass car with this kit, just slightly faster than mine
    2005 GTO
    Quote Originally Posted by DarkFormula View Post
    Hey man glad to see you here.thanks for the kind words,cant wait till we can do it again.
  1. Replies: 2
    Last Post: 10-16-2009, 12:45 AM
  2. Replies: 45
    Last Post: 06-14-2006, 05:49 PM
  3. Replies: 14
    Last Post: 12-28-2005, 07:00 PM
  4. Twin Turbo LS2 - 522 HP at 6.25 psi
    By peter@aps in forum Forced Induction
    Last Post: 10-20-2005, 02:00 PM
