Results 1 to 20 of 44
02-18-2009, 07:06 AM #1
Building a drag race only F-Body, Engine Selection
I'm building a track-only stock-appearance beast for drag racing. I don't have a whole lot of money, so i purchased a 1997 V6 firebird body to work with. I'm not sure wether or not i should use a Gen III engine or LT-x series engine. My gut feeling tells me i'd be happier with a Gen III; but since cost is the #1 factor, i'm open to all kinds of suggestions. Maximum amount of HP/Torque is the goal.. forced induction, nitrous, or naturally aspirated also doesn't matter..
I've looked into using truck engines as a cheap alternative. Weight doesn't matter, i can find creative ways to make up the weight difference. Suspension, rear end, or other suggestions are very welcome.... I'm a novice, and don't mind being told what's really up.
03-01-2009, 06:10 PM #2
- Apr 2001
- Surf City, NC
Black/Screaming Yellow- 99 S/C TA WS6 & 04 Cobra
1999 Trans Am WS6 Black - Forged 346, P1SC (8psi), TH-400, and 12 bolt(3.73's)
10.29@129 w/1.60 sixty foot
2004 Screaming Yellow Mustang Cobra - Whipple 2.3, Exhaust, & CCW's...My DD
03-01-2009, 07:37 PM #3
I'd like to see 850hp + on race fuel (or E85); forced induction.
03-01-2009, 11:30 PM #4
400+ ci LQX motor with a 300 shot
03-02-2009, 05:04 AM #5
will a stock LQ4 survive a 300 shot?
03-02-2009, 05:14 AM #6
Well if its a full blown race car I'd assume you'd be getting forged internals and if you were going with something like a 408 stroker you'd have to buy a new roatating assembly so why not go forged? I dunno, but I don't think a stock LQ4 will survive a 300 shot for all that long....?
03-02-2009, 05:20 AM #7
See.. That's the thing; I looked at almose every engine out there, and the LQ4 seemed like the best choice: 18psi stock bottom end due to it's dished pistons and cast iron design. Of course valve train would change, maybe cam, but in it's stock form I could easily see the power levels I wanted.. But since I've never actually tried it, I don't know for sure
03-02-2009, 05:26 AM #8
03-02-2009, 06:04 AM #9
well, with that, I was meaning with some type of forced induction, not n/a
03-02-2009, 06:07 AM #10
03-02-2009, 06:21 AM #11
Since I'll be running in the 1/4 and 1/8 mile, top end really isn't that important. I'd say 800+ RWHP/800 Torque would be okay; i may be aiming for too much hp but i would like to see mid 5's in the 1/8 and mid to high 7's in the 1/4.
03-02-2009, 06:30 AM #12
03-02-2009, 06:34 AM #13
I'm quite the novice. I am however very creative in finding solutions to problems. So hopefully I am on the right course with this LQ4 idea.
03-02-2009, 12:00 PM #14
- Mar 2009
- Fort Salonga NY
Quick Silver- 2001 Corvette
Save your self some money
I got a killer LSX race engine for sale. It's a proven combo ran mid 7's with twin 76s at 3400lbs on a radial.
Here is a link with the info:
http://www.corvettemajor.com/forsale.php
03-02-2009, 08:06 PM #15
- Boca Raton, FL
Black- 2002 Camaro Z28
your gonna need a bit more hp/tq to reach mid 5's and 7's i'm thinking 1100+ depending on weight, etc.
03-02-2009, 08:20 PM #16
- Sep 2007
- Denton, Texas soon Lafayette, Louisiana
Blue- 2002 Z28 Camaro M6
That is about right. One of my best friends has a full tube chassis 69 Camaro (around 2300 lbs) that runs right around 5.3s in the 1/8 and makes about 1200 with a 540 big block alcohol motor with mechanical fuel injection. Very expensive to run that kind of speed on motor alone. Even the drivetrain parts are insane cost wise compared to my build.
There was a car around here that belonged to one of the mechanics at RPM that I believe ran 6s in the 1/8 with an LQ9 bottom end and a 300 hp dry shot.
03-02-2009, 09:52 PM #17
Yeah, i think Nitrous may be the ticket. 300 Shot may be more realistic. What about using a big block carb motor? Do you think that may be more cost effective than running an LSx based motor?
03-02-2009, 10:03 PM #18
03-02-2009, 10:38 PM #19
Why carb over FI? I'm a big FI fan..... just curious....
03-03-2009, 06:06 AM #20
Corvette Engine Selection - Project C4orce Update
By Ed Blown Vert in forum CorvetteReplies: 0Last Post: 04-23-2009, 11:40 PM -
Question: Building a drag race only F-Body, Engine Selection
By first01SS in forum General HelpReplies: 12Last Post: 02-23-2009, 12:46 PM -
The Last Drag Race at Lions Drag Strip
By Ed Blown Vert in forum Almost Anything GoesReplies: 8Last Post: 06-29-2008, 02:38 PM -
building engine
By 69camarokid in forum Internal EngineReplies: 2Last Post: 08-28-2005, 06:53 PM -
I need help with a throttle body selection?
By blackSS01 in forum General HelpReplies: 11Last Post: 08-07-2005, 09:22 PM
