Results 1 to 17 of 17
    Chicago IL
    2000 A4 WS6
    Questions/suggestions needed
    Ok.... my cars a stock 00 WS6. I'm putting in a transgo hd2 shift kit... I plan on going with a stall in the future..... However I dont have the money for the rearend, gear, stall etc etc at this point.. My question is...... What trans cooler should I install at this point? I want to drive my car on the street with a 3k stall in the future.. Its not a daily driver! I was thinking the 24k from B&M but will that handle the stall and 500-700hp I plan on firing through it in the near future?
    Thanks alot guys I feel like such a noob
    Itllrun
    Chicago IL
    2000 A4 WS6
    I've been doing alot of research and I'm going to go with the B&M 24k. I wanna pull this damn trans and get this done b4 the tracks open in april
    Senior Member bills98ta's Avatar
    Feb 2007
    St Thomas, PA
    I just went generic, but big. I don't think to big can hurt anything.
    Arizona
    Bill is right. Figure out where you want to mount it and then stick the biggest one you can fit in that area.
    Feb 2007
    St Thomas, PA
    I tell that to my women all the time !!!
    ( the Bill is right part ) LOL !!!
    Arizona
    Quote Originally Posted by bills98ta View Post
    And how does that work out for ya???
    Member crazy dave ls1's Avatar
    Aug 2008
    texas
    2002 z/28
    yea I went with a 24000 gvw from napa for 46 bucks, did you leave the radiator cooler in the loop?I've been afraid to pull the rad. cooler out of the loop till I can get a trans temp gauge.
    Feb 2007
    St Thomas, PA
    It Didn't....
    Feb 2007
    St Thomas, PA
    Quote Originally Posted by crazy dave ls1 View Post
    I did leave mine in the loop. More cooling !
    Arizona
    It Didn't....
    Same here
    I was hoping you had a trick I didn't know about I could try.
    Arizona
    Yes just as Bill states, I left the radiator in the loop as well, the more the better. I do this on every car.
    Just make sure you tap into the return line to the trans for the auxillary cooler so it doesn't have to work as hard,,,letting the radiator get the brunt of it first. That way the auxillary cooler that is more efficient does an even better job of cooling.
    Chicago IL
    2000 A4 WS6
    Sweet thanks guys I'll keep all that in mind when I do it. I'm hoping 1st or 2nd week in march. 2nd to 3rd shift at the track is sloooooow and sluggish. cant wait for the shift kit to get rid of it.
    Pittsburgh
    2008 Hummer H3
    Thumbs up
    Quote Originally Posted by Itllrun View Post
    Yes I agree with the others. A cooler fluid temp gives crisper shifts aswell. Can sometimes make some difference in those ETs too. You may know this already, but make sure you mount your cooler where it gets cooler air.
    Holy SshhhhhCHirp!! C ya!
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    Where did you guys mount your coolers?
    Chicago IL
    2000 A4 WS6
    Good question........... i've heard mixed answers on where to mount it...... Some say not to mount it in the raditor and some say thats where they mounted it. wtf I'd think the raditor cause more cool air is around there am I wrong? Thanks...
    Arizona
    On the 4th gen I didn't have much choice but to mount it on the front of the consdensor.
    There was really no room anywhere else to mount it for me, especially the big cooler that I wanted to stick in there unless I started hacking the car up,,,something I wasn't going to do.
    My other option was to mount it behind the radiator but in front of the coolant fans. This was a way to hide it but the idea of the cooler getting already heated air from the condensor and the radiator changed my mind.
    On the older cars I prefer to attatch the cooler to the rear of the grille. It's not near the radiator but it's still front and center and has room for air to run through as well as behind it. Just no room on the 4th gens to do anything like that.
    Chicago IL
    2000 A4 WS6
    Damnit I wish I knew where the hell I should mount this beast when I put it in.
  1. Suggestions on Rear Shocks Needed
    By 97ramair in forum Suspension and Handling
    Last Post: 09-22-2010, 06:32 AM
  2. Help: Urgent suggestions needed
    By SteelCityTA in forum General Help
    Last Post: 03-28-2009, 05:31 AM
  3. new clutch on the way suggestions needed
    By L3thal-Z28 in forum Manual Transmission
    Last Post: 02-18-2009, 08:26 PM
  4. New battery needed any suggestions?
    By sootymethod in forum General Help
    Last Post: 08-30-2006, 01:01 PM
  5. suggestions needed for mods...
    By SmokinSS in forum Internal Engine
    Last Post: 10-04-2005, 03:46 PM
