Thread: Think I messed up?
02-15-2009, 05:02 PM #1
Think I messed up?
For some reason I don't remember bolting the pickup tube to my oil pump...? I'm debating weather or not to rip the front cover off before first start up. Motor is back in the car and it is gonna be a pia to remove the cover again, but I think It'd be best just to check. Anyone know what size the bolt is? I think its 8mm with a 10mm head? I just don't remember bolting it back in
02-15-2009, 06:23 PM #2
You'd almost have to bolt it in first before you bolted the bracket to the windage tray. But if your in doubt, I'd pull the cover & look !
02-15-2009, 08:36 PM #3
02-16-2009, 02:42 AM #4
Got ya... It's a bitch to do from the front cover, but it can be done, and you would remember doing that....
Did you end up with an extra bolt at the end ?
02-16-2009, 04:42 AM #5
I would double check, its a PITA but on the same token you will be sorry if you didnt...
02-16-2009, 06:22 AM #6
No, I don't know where the bolt is or looks like. The shortblock I bought came with pickup, but no pump or bolt and I was gonna recycle the bolt from the old pickup tube. What size is it agian.
Yea, now that I think about it I'm pretty sure I forgot to do it...
02-16-2009, 09:22 AM #7My Neighbors Hate Me!!!
- Jun 2006
- Ft. Lee, Virginia
Artic White- 2001 Chevy Camaro SS
Im pretty sure it's a 10mm. Here's a pic of it. Attachment 18155
02-16-2009, 10:12 AM #8Member
- Sep 2008
- kansas city mo
black- 2000 camaro ss
it is a 10mm and im sure if you put it in you would remember it (its a bitch). lol man tear her back apart.
02-16-2009, 04:05 PM #9
Shitty! I bet you wont do that again!
If the standard offset angle of a snap-on wrench doent work for you, go out and buy a 10mm RATCHETING "FLEX HEAD" wrench. That will make it a whole lot easier for that bolt. You know you at least have to check!
02-16-2009, 04:54 PM #10
yep, gotta tear it apart and check. That sucks. Is it completely back together? Water pump and all? I didn't have a single problem with that bolt doing it with it in the car when I did my cam swap but I know lots of people do and I can definitely see why. I just got lucky on mine and it threaded right up and went in without a problem. I put a rag in the oil pan to keep the bolt from rolling into the oil pan in case I dropped it. I forgot to remove that rag but I caught it before getting the pump on. That would've been bad. I've seen what happens when a rag gets left in there....it's ugly so if you use a rag in the oil pan make sure you take it out.
02-16-2009, 05:42 PM #11
Dont feel bad. I dropped a washer on top of my intake valve when doing my FAST 92/92 install. By the grace of anti-christ, I went looking in all the chambers to look at the CNC job. Well by gollie, WTF is that sitting there?!?!?!?! A damn steel washer!!!
We all do silly things when in a hurry. Welcome to the club. I would rather have your problem then the problems/mods that await me.
02-16-2009, 07:32 PM #12
I'm gonna drop the motor back out and pull the front cover off. The front accessories are off and I only have the k member bolted in so 3 bolts arent a huge deal to undo to have it out of the car. I'll have pics of the whole rebuild process but I basically did everything with a cherry picker, engine stand, and a 3 drawer tool box (Craftsmen cause I can't afford Snap on, Matco, etc), and my uncle gave me an old air compressor so for the last part of the build I had air tools. I dropped the motor, tranny, and k member out the bottom and it was actually surprisingly easy I guess in worrying about all that stuff I forgot one little thing!!!
this kid is messed up
By LT1 > LS1 in forum Almost Anything GoesReplies: 15Last Post: 02-05-2009, 09:12 AM -
I think I messed up :(
By david_viny in forum General HelpReplies: 20Last Post: 07-24-2008, 01:51 PM -
my car got messed with
By transamdude99 in forum Firebird / WS6Replies: 27Last Post: 03-05-2008, 08:21 AM -
i can't believe this, this is messed up.
By 1fastcamarosss11 in forum Almost Anything GoesReplies: 9Last Post: 11-30-2006, 03:39 PM
