    OKC
    Artic White
    2002 ws6
    Help me build my street car
    Alright all. Of course I want to start modding my car but I want to do it right the first time. This is a weekend driver only. very few miles and will not being seeing a drag strip but maybe once a year just for fun. It will see more of a street course race environment than anything. So here is what I have for suspension ideas, tell me what you would change, not do, or add to my list. Also, another question is whether or not you think a tunnel braced torque arm would benefit me or if I should leave the stock alone.
    Suspension mods:
    Hotchkis progressive springs-already installed
    Koni SA's-already installed
    UMI 3-point SFC's-own (not installed yet)
    Spohn adjustable panhard bar (should I get spherical rod ended? what does
    it help?)
    Spohn Adjustable LCA's w/Spherical/Poly Combo
    Spohn Adjustable Torque Arm with tunnel brace and driveshaft loop (is this
    necessary?)
    Strano hollow swaybar set
    So let the suggestions fly everyone.
    Thanks!
    Sell Hotchkis springs and get Stranos. I did that with my ProKit and upgraded to them. Worth every penny.
    Seem like you are on the right track for sure!
    OKC
    Artic White
    2002 ws6
    Would you still go with the tunnel braced torque arm for a street application? and would you upgrade to the spherical rod ended panhard bar?
    Thanks! and Strano's springs would really outshine mine enough to make a difference?
    St. Clair Shores. Michigan
    `98 Formula M6 HdTp
    The Hotchkis springs are progressive where as the Strano's are linear so the Strano's may ride a little harsher but I would think the Koni's more then make up for that. I have Strano's w/Koni's and I'm quite satisfied with the ride as compared to stock.
    And for a streetcar you might look at a cross member mounted Torqe Arm vs a tunnel mount. JMO
    Craig
    Semi Retired Street Racer
    Gone but not forgoten
    NBM `98 Formula M6 HdTp
    1 of 1 Build Date 3/12/98
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    I'd change the springs for linear spring rates.
    As for the PHR + LCA, I'd get the rod-ends... but make sure they are good QA1 rod-ends.
    Eugenio_SS
    OKC
    Artic White
    2002 ws6
    Quote Originally Posted by Eugenio_SS View Post
    Will having the dual adjustable (rod-ended) LCA's and Panhard Bar make a louder application? I want the car to perform well but I don't want a loud rattly car.
    That guy thearborbarber's Avatar
    SoDak
    White over Red
    1991 Suburban
    I went with double rod ends on the phb and poly/rod ends on the lca's. NO appreciable increase in road noise.
    Jun 2002
    Montreal, CANADA
    triple-black
    Quote Originally Posted by architect7 View Post
    If they are good quality rod-ends, they are quiet...
    I find polyurethane louder with the squish-squish sounds.
    Member Blue28's Avatar
    Ca.
    Navy Blue
    1999 Camaro Z28
    Lightbulb
    IMO, keep the hotshkis springs, unless your unhappy with them.
    As far as a T.A. get a stock lenght adj. , and a UMI T.A. relocation kit, poly trans mount, and T.A. front mount bushing. For Rear LCA, DKT performance double JJ (johnny Joints) arms Quiet with great articulation, and fully rebuildableby yourself. or For less get the J&M hotparts LCA with the 3piece polyball bushingson both ends, or with the Extreme joint on one end. For PHBs get a on car adjustable poly/rod-end combo. Up front get a GlobalWest upper control arm bushing kit, with lifetime ,no deflection "Del-a-lum" bushings#GLS1082. After all of this, get the swaybars last.
    Jun 2002
    Montreal, CANADA
    triple-black
    poly trans mount will generate insane amounts of noise in the cockpit.
    OKC
    Artic White
    2002 ws6
    You're saying a tunnel braced torque arm will generate less noise?
    Ca.
    Navy Blue
    1999 Camaro Z28
    Lightbulb
    If you get the energy suspension trans mount it has the two preload bumps; cut or grind them off! Now when you mount it up go ahead and still use the preload plate.
    With the preload bumps removed there's only a very slight noise increase!
    Otherwise if you leave the preload bumps intact it's crazy loud!
    Been there, done that!
  1. True Street Build
    By scott5 in forum Forced Induction
    Last Post: 11-14-2015, 12:16 PM
  2. James's 2001 WS6 Street/Srtip build
    By chevyoverford11 in forum Firebird / WS6
    Last Post: 10-04-2015, 06:06 AM
  3. Replies: 3
    Last Post: 09-30-2015, 08:04 AM
  4. Nastiest cam for a street/ budget build.
    By 1fastkingcab in forum Internal Engine
    Last Post: 10-25-2009, 05:21 AM
  5. Looking to build an all motor street monster
    By JHayesLS1 in forum Internal Engine
    Last Post: 12-03-2007, 04:45 PM
