Thread: rust
02-05-2009, 02:29 PM #1Junior Member
- canada
black- 2001 Pontiac Trans Am WS6
rust
has anyone noticed that rust starts to acumulate on the rear floor pan
where the traling arm bolts in to further up whare the metal meets the
floor pan. is this common and is there a way to fix it. or should i leave
it allone. This is not my car. my car has rusted a little in the same spot.
I had grinded one side and just sprayed rust paint on it. a couple of coats.
i did not primer it. but i got rid of the rust on that side. The other side still
has a little bit of rust on it. should i leave it or repair it too. Is it a good idea
to be gindin it. or should i leave it allone. since i have rusproofed the
car. I spray these spot very of with rust check oil. will the oil spay
stop it. am i okay if i just keep sprayng it with oil often or should i remove
the rust on the other side too. I also oil sprayed the car from the inside too.
here is a picture of the area i am talking about. 2 pices of meatal meet there.
02-05-2009, 02:57 PM #2Junior Member
- canada
for some reason my computer wont let me put the picture up.
the spot i am talking about is infront of the fuel filter. it is where the pecie
of meatal where the trailing arm bolts into but further up where it is attached
to the floor pan where meet. its at the seam it curves along the floor pan.
02-07-2009, 03:03 PM #3
If it is what I think there really isnt a good easy fix. What I would do is get some "rust paint" and dont grind the area just knock the lose stuff off and clean/dry then paint.
02-07-2009, 05:10 PM #4
Just put some POR 15 right over top of it, problem solved.
Help: Have rust, need help
By FinZ28 in forum General HelpReplies: 11Last Post: 03-28-2012, 04:52 PM -
Pontiac Rust Prevention - Rust No More
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 04-22-2011, 12:20 PM -
Need some help with RUST
By 99WS6MAN in forum Showcar and DetailingReplies: 6Last Post: 08-07-2009, 07:11 PM -
Rust Removal Guide - Rust Eradication
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 11-20-2008, 02:40 PM -
will the tsp y rust?
By GottaHaveLS1 in forum External EngineReplies: 2Last Post: 05-25-2006, 05:40 AM
