Results 1 to 14 of 14
    las cruces nm
    Sport Gold Metallic
    98 z28...sold
    Hid light pattern
    If had my hid's for about a year now and I have always wondered if my light pattern on the floor is right. The metal frame thing that locks in the light bulbs is bent and worn out so I was thinking that maybe my light pattern could be better.They are 8k with reg bulbs in fog's.This is what mine looks like, what do yours look like?
    las cruces nm
    Sport Gold Metallic
    98 z28...sold
    Nobody has wondered this... really just me
    Member One_Bad_TA's Avatar
    Jan 2008
    Cleveland, Ohio
    2000 Trans Am WS.6
    I have mine pointed a little higher but my beam seems to be a little wider. But yours dont look like there off by much if it is
    Member WS-6's Avatar
    Feb 2008
    NW Indiana
    2000 T/A WS-6
    It look pretty good to me here is one of my lows only:
    Feb 2008
    NW Indiana
    2000 T/A WS-6
    ^ they are 4300K
    Pa
    Blue
    2000 TA
    Look at the difference in light output. The 4300 or 5000 will put out significantly more light than 8000.
    Member Lutzfire24's Avatar
    Tampa, FL.
    2002 Trans Am WS6
    Quote Originally Posted by DUBL0WS6 View Post
    las cruces nm
    Sport Gold Metallic
    98 z28...sold
    I just put in a set of 6k in my dads 04 ram and there really bright. 8k are more for the look of the headlight.
    Jan 2008
    Cleveland, Ohio
    2000 Trans Am WS.6
    6k is the brightest and you can barely notice a difference in brightness between 6k and 8k if at all. All you can really notice is the color
    Senior Member Redphoenix1998's Avatar
    Apr 2002
    San Jose
    1998 Pontiac Trans Am
    I have a set of 10k's on mine and it lights up everything, even the overhead freeway signs. I aligned the headlights to have theright angle to the ground. I'll get pics as soon as the rain here stops.
    las cruces nm
    Sport Gold Metallic
    98 z28...sold
    I noticed a big difference from 6k to 8k in both color and brightness. any of you guys put an hid kit on a projector headlight. I've been wondering how much of a difference there is.
    Orlando FL
    Red+White Top and Stripes
    2000TransAmConvertible A4
    They look fine to me.
    Jan 2008
    Cleveland, Ohio
    2000 Trans Am WS.6
    Quote Originally Posted by Goldmember View Post
    If you put 10k on both a regular headlight and projector the projector headlight will seem less blue because the light is not pointed as high and more focused. If you bend down to the level of the projector beam if is much brighter because of the focus. I have 10k on my TA and my friends have a set on their 08 WRX and Passat, mine is noticeably bluer but since their projectors focus the light it is brighter at night
    Pa
    Blue
    2000 TA
    5K 3200 lumens
    6K 2800 lumens
    8K 2550 Lumens
    10K 2200 Lumens
    Also remember that the blue light is harder to see than either the white or yellowish light and will cause eye strain over extended driving periods.
  1. Lug pattern
    By RamAM02 in forum Wheels and Tires
    Last Post: 03-05-2011, 03:28 PM
  2. Question: Bolt Pattern
    By amysboxers in forum Wheels and Tires
    Last Post: 02-25-2011, 11:04 AM
  3. lug pattern
    By 20redbody00 in forum Wheels and Tires
    Last Post: 11-27-2009, 05:45 PM
  4. Bolt pattern?
    By ezwip in forum Wheels and Tires
    Last Post: 06-15-2008, 07:44 PM
  5. headlight light pattern question/hid kit
    By zwaldo in forum Appearance Section
    Last Post: 09-06-2007, 09:43 AM
