Results 1 to 13 of 13
Thread: on/off fan temps with 180 stat
01-17-2006, 11:25 PM #1
What's a popular setting to have the low fan on/off temps and high fan on/off temps for a 180 stat? Also what about for the 195 stat...in case I decide to keep the sotck stat temp in there. I put the preadtor canned tune in the other day...pretty sure it dropped the on/off temps for low and high speed. I remember the high speed came on at 205 and shut off at 197....low came on at 196.1 I think.
01-18-2006, 10:16 AM #2
wow...tons of input on this subject...doeoodoeoodoeooodoeodooe
01-18-2006, 08:06 PM #3
Bastards....BASTARDS ALL OF YOU
I'll go ask at ls1tech.....bastards
01-18-2006, 08:26 PM #4SUPREME member-oderator
- Nov 2005
- Lost in Texas
Custom Slate Blue- 99 B4C
with a 180 you want lows on about 181 and highs on about 190-193. the high on temp isn't really important
01-18-2006, 08:42 PM #5SUPREME member-oderator
- Nov 2005
- Lost in Texas
hey how do you like the predator, i have one on the way
01-18-2006, 09:31 PM #6What about the off temps?
Originally Posted by z_driver1
Dude the predator is awesome..and I really like that you can get custom tunes for it. Plus it's simple to use....and does everything I need it to do and then some.
01-18-2006, 09:33 PM #7SUPREME member-oderator
- Nov 2005
- Lost in Texas
I picked it because it lets you delete rear o2s egr and air, i have mac mids and ORY that should be here fri
01-18-2006, 09:34 PM #8SUPREME member-oderator
- Nov 2005
- Lost in Texas
lemme research some more before i give you off temps
01-18-2006, 09:35 PM #9SUPREME member-oderator
- Nov 2005
- Lost in Texas
high shut off 183, still workin on lows
01-18-2006, 09:57 PM #10
I found it bro..thanks though. Here's a link on ls1tech...shows how to adjust the fuel and timing too.http://www.ls1tech.com/forums/showpo...0&postcount=10
says on there 192 on 187 off for low...197 on 191 off for high
01-18-2006, 10:30 PM #11SUPREME member-oderator
- Nov 2005
- Lost in Texas
That's a little hot, you put in a cooler stat to run cooler right? lol. Relate the new numers to the old numbers. High came on 10 degrees above stat temp, turned off at any temp in the low fan range, low fans come on as the stat opens in order to maintiain stat temp. My temps basically follow the formula of the original in order to take full advantage of the lower temp stat. His numbers are very well good enough, I just prefer to stay as low as the stat I put in.
01-19-2006, 07:53 AM #12
This is the settings I am currently running on Sara with a 180 thermo:
1st Fan on/off - 194/185
2nd Fan on/off - 204/195
SteveC
01-19-2006, 08:17 AM #13Senior Member
- Jul 2005
- Jacksonville, FL
These settings are from an old post by James at RWTD I wrote down from the old board a couple years ago:
Stock Tstat
fan 1 on/off 209/200
fan 2 on/off 219/210
180
fan 1 on/off 194/185
fan 2 on/off 204/195
160
fan 1 on/off 184/175
fan 2 on/off 194/185
I'm been using his 160 settings.
Temps go up, oil pressure goes down
By karpetcm in forum General HelpReplies: 7Last Post: 07-17-2010, 03:42 PM -
Help: High temps = pinging
By 02fbody35th in forum General HelpReplies: 8Last Post: 05-24-2010, 06:46 PM -
Under hood temps
By peteSS in forum External EngineReplies: 1Last Post: 11-24-2007, 09:00 AM -
Fan temps? 160? 195? help please..
By Z28LS1 in forum External EngineReplies: 8Last Post: 06-03-2007, 08:19 PM -
Exhuast temps?
By grandkodiak in forum Forced InductionReplies: 0Last Post: 05-11-2006, 08:06 PM
